APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Resettable circuit breakers
Enables a quick recovery from overload events -
Cold-start capable
Provides temporary battery power when the utility power is out -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
SmartSlot
Customize UPS capabilities with management cards -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment -
Network manageable
Provides remote power management of the UPS over the network -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Boost and Trim Automatic Voltage Regulation (AVR)
Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models) -
Serial connectivity
Provides management of the UPS via a serial port -
Disconnected battery notification
Warns when a battery is not available to provide backup power -
Adjustable voltage-transfer points
Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation -
Rack/Tower convertible
Protects the initial investment in the UPS when migrating from tower to rack-mount environment
- APC Smart-UPS - UPS - 4 kW - 5000 VA
- UPS - external
- Rack Size
- 5U
- 97.7 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 220/230/240 V ± 5%
- Power Capacity
- 4 kW / 5000 VA
- Input Connectors
- 1 x hardwire 3-wire
- Output connectors
- 8 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 2
- Run Time (Up To)
- 9.4 min at full load
- Networking
- Ethernet 10/100, RS-232
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- 48.3 cm x 66 cm x 22.2 cm
- 2-year warranty
- Designed For
- P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX432, NBWL0356A
- UPS - external
- Battery Enclosure Type
- Internal
- Height (Rack Units)
- 5U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 50/60 Hz
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V ± 5% - 50/60 Hz
- Power Capacity
- 4 kW / 5000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 480 joules
- Quantity
- 2
- Technology
- Lead Acid
- Run Time (Up To)
- Recharge Time
- 3 hours
- Remote Management Interface
- 1 x management (RS-232) - 9 pin D-Sub (DB-9) , 1 x management (Ethernet) - RJ-45
- Expansion Slots
- 1 (total) / 0 (free) x SmartSlot
- Cables Included
- Serial cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LED indicators, noise filtering
- C-Tick, GOST, GS, VDE, EN 50091-2, EN 50091-1
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 53 dBA
- 48.3 cm
- 66 cm
- 22.2 cm
- 97.7 kg
- Shipping Width
- 61 cm
- Shipping Depth
- 76.2 cm
- Shipping Height
- 63.5 cm
- Shipping Weight
- 107 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR2101, AR2102BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140G, AR3140W, AR3150, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £207.79 |
APC 1U Vertical Cable Organiser | In Stock | £125.54 |
APC 1U Horizontal Cable Organiser | In Stock | £56.31 |
APC Netshelter heavy duty shelf | In Stock | £144.40 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £307.69 |
APC 2-Post Mounting Kit for Smart-UPS | In Stock | £177.76 |
APC Replacement Battery Cartridge RBC55 | In Stock | £434.66 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £333.11 |
APC Temperature and Humidity Sensor | In Stock | £132.24 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £298.45 |
APC Cable Managers (Qty 10) | In Stock | £36.92 |
APC 2G Power distribution strip | In Stock | £659.26 |
APC Rack PDU 2G METERED ZEROU | In Stock | £702.58 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £520.88 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,015.71 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £974.29 |
APC Vertical Cable Organizer, NetShelter SX, 42U | In Stock | £96.20 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £82.25 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,498.91 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £99.34 |
APC 1U Blanking Panel Kit | In Stock | £35.32 |
APC Service Pack 3 Year Warranty Extension (for new purchases) | In Stock | £584.86 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £57.08 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.79 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,710.67 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.80 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £648.06 |
APC Extended Warranty Renewal Technical Support (Renewal) 3 Years | In Stock | £830.49 |
APC Metered Rack PDU | In Stock | £855.83 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £772.11 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £269.76 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,114.33 |
APC Service Pack 1 Year Warranty Extension | In Stock | £268.20 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £63.44 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £679.40 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,282.94 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £165.67 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,326.23 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £84.20 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £465.24 |
