Wide input voltage range is designed for harsh electrical environments to save battery life. LED indicators provide easy-to-read status of the unit and utility power conditions. Boost and trim Automatic Voltage Regulation (AVR) eliminates voltage fluctuations as a source of AV signal degradation and component power-supply stress. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys.
- APC Smart-UPS 3000 LCD - UPS - 2.7 kW - 3000 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 44.3 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 2.7 kW / 3000 VA
- Input Connectors
- Power IEC 60320 C20, power CEE 7/7, power BS 1363A
- Output connectors
- 8 x power IEC 60320 C13 , 3 x IEC jumper , 1 x power IEC 60320 C19
- Battery
- Lead Acid
- Run Time (Up To)
- 3.2 min at full load
- Networking
- RS-232, USB
- 48 cm x 68.3 cm x 8.6 cm
- 3-year warranty
- Designed For
- P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3155W, AR3305W, AR3340G, AR3355W, AR3357X674, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Height (Rack Units)
- 2U
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 299 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 220/230/240 V
- Power Capacity
- 2.7 kW / 3000 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 320 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 3.2 min at full load , 11.5 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x USB , 1 x serial
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Serial cable , USB cable , Power cable - integrated - 2 m
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators
- C-Tick, GOST, EN 60950, GS, VDE, IEC 62040-1-1, RoHS Exemption 7b, IEC 62040-2, IRAM, WEEE, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 48 cm
- 68.3 cm
- 8.6 cm
- 44.3 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 98 cm
- Shipping Height
- 25.4 cm
- Shipping Weight
- 51.7 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £29.89 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £48.99 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £50.90 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £202.03 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.74 |
APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid | In Stock | £430.93 |
APC Power cable - 2.4 m | In Stock | £84.15 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £299.80 |
APC 3Yr Extended Warranty SP | In Stock | £325.83 |
APC Temperature and Humidity Sensor | In Stock | £133.14 |
APC POWER CORD C13 TO C20 1.98m Black | In Stock | £52.05 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.81 |
APC Power Cord Locking C19 to IEC309-16A 3.0m | In Stock | £84.15 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £68.64 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £53.14 |
APC Power Cable (pack of 6) 1.22m | In Stock | £87.46 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.85 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £101.73 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £636.90 |
APC Extended Warranty Service Pack Technical Support 1 Year | In Stock | £135.83 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £736.14 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.44 |
APC Switched PDU 10A 0U C13x16 | In Stock | £1,164.00 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £671.74 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,258.20 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £162.29 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £81.93 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £470.30 |
