APC Smart-UPS 3000VA LCD RM 2U 230V
Quicklinx: 7KRLWS00 Mfr#: SMT3000RMI2U
Type: UPS
Power Rating: 2.7kW
£1,905.52 ex VAT
£2,286.62 inc VAT
Wide input voltage range is designed for harsh electrical environments to save battery life. LED indicators provide easy-to-read status of the unit and utility power conditions. Boost and trim Automatic Voltage Regulation (AVR) eliminates voltage fluctuations as a source of AV signal degradation and component power-supply stress. Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys.
APC Smart-UPS 3000 LCD - UPS - 2.7 kW - 3000 VA
UPS - rack-mountable
Rack Size
2U
44.3 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
2.7 kW / 3000 VA
Input Connectors
Power IEC 60320 C20, power CEE 7/7, power BS 1363A
Output connectors
8 x power IEC 60320 C13 ¦ 3 x IEC jumper ¦ 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.2 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
3-year warranty
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3155W, AR3305W, AR3340G, AR3355W, AR3357X674, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 299 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V
Power Capacity
2.7 kW / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
3.2 min at full load ¦ 11.5 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x USB ¦ 1 x serial
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable ¦ USB cable ¦ Power cable - integrated - 2 m
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators
C-Tick, GOST, EN 60950, GS, VDE, IEC 62040-1-1, RoHS Exemption 7b, IEC 62040-2, IRAM, WEEE, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years ¦ Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
48 cm
68.3 cm
8.6 cm
44.3 kg
Shipping Width
60 cm
Shipping Depth
98 cm
Shipping Height
25.4 cm
Shipping Weight
51.7 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
7KRL APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
7KRL APC - Power cable - Male-Female - 1.98 m In Stock £47.79
7KRL APC Basic Rack-Mount PDU - power distribution strip In Stock £197.72
7KRL APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
7KRL APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £56.28
7KRL APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £416.09
7KRL APC Power cable - 2.4 m In Stock £82.25
7KRL APC Rack PDU Basic Zero U 16A 208/230V In Stock £286.90
7KRL APC 2-Post Mounting Kit for Smart-UPS In Stock £169.50
7KRL APC 3Yr Extended Warranty SP In Stock £288.00
7KRL APC Temperature and Humidity Sensor In Stock £133.79
7KRL APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £271.25
7KRL APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.12
7KRL APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £85.03
7KRL APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.95
7KRL APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
7KRL APC Power Cable (pack of 6) 1.22m In Stock £84.43
7KRL APC Dry Contact I/O SmartSlot Card In Stock £165.13
7KRL APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
7KRL APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
7KRL APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £614.64
7KRL APC Extended Warranty Service Pack Technical Support 1 Year In Stock £120.61
7KRL APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
7KRL APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
7KRL APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
7KRL APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
7KRL APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.48
7KRL APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £155.82
7KRL APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.21
Type: UPS
Power Rating: 2.7kW
Brand: APC
Price Range Ex VAT: £1500+
