APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V
Quicklinx: FFKWWS00 Mfr#: SMT3000RMI2UNC
Power Rating: 2700Watt
More than 50 In Stock
£2,141.29 ex VAT
£2,569.54 inc VAT
APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
APC Smart-UPS 3000VA LCD RM - UPS - 2700 Watt - 3000 VA - with APC UPS Network Management Card
UPS - rack-mountable
Rack Size
2U
44.19 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1
Output connectors
8 x power IEC 60320 C13 ¦ 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
3.2 min at full load
Ethernet, RS-232, USB
Rack mounting rails, temperature probe
48 cm x 68.3 cm x 8.6 cm
3-year warranty
Bundled with
P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX432, NBPD0180, NBWL0356A
Height (Rack Units)
2U
Bundled with
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
1
Output Voltage
AC 230 V ± 5% - 47 - 63 Hz
Power Capacity
2700 Watt / 3000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
320 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
3.2 min at full load ¦ 11.5 min at half load
Recharge Time
3 hours
Transfer Time
4 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (Ethernet) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external , USB cable - external , Power cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
GS, VDE, IEC 62040-2, IRAM, RoHS, WEEE, REACH, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years ¦ Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
55 dBA
48 cm
68.3 cm
8.6 cm
44.19 kg
Shipping Width
60 cm
Shipping Depth
98 cm
Shipping Height
25.4 cm
Shipping Weight
51.59 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF202BLK, ACF400, ACF402, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR201, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3180G, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, NBPD0180, NBRK0201, NBRK0320, NBRK0320E, NBRK0551, NBWL0355, NBWL0356A
FFKW APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
FFKW APC - Power cable - Male-Female - 1.98 m In Stock £47.79
FFKW APC Basic Rack-Mount PDU - power distribution strip In Stock £197.72
FFKW APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
FFKW APC Pwr Cord, 16A, 200-240V, C19 to UK Plug In Stock £56.28
FFKW APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £416.09
FFKW APC Power cable - 2.4 m In Stock £82.25
FFKW APC Rack PDU Basic Zero U 16A 208/230V In Stock £286.90
FFKW APC 3Yr Extended Warranty SP In Stock £288.00
FFKW APC Temperature and Humidity Sensor In Stock £133.79
FFKW APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £271.25
FFKW APC Smart-UPS X 120V EXT BATTERY In Stock £871.29
FFKW APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £953.12
FFKW APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £85.03
FFKW APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £51.95
FFKW APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
FFKW APC Power Cable (pack of 6) 1.22m In Stock £84.43
FFKW APC Dry Contact I/O SmartSlot Card In Stock £165.13
FFKW APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
FFKW APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
FFKW APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £614.64
FFKW APC Extended Warranty Service Pack Technical Support 1 Year In Stock £120.61
FFKW APC Switched Rack PDU AC 208-230 V Ethernet In Stock £731.73
FFKW APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
FFKW APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
FFKW APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
FFKW APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,217.48
FFKW APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £155.82
FFKW APC Rack PDU Basic 0U/1U 100-240V/ In Stock £80.21
Brand: APC
Price Range Ex VAT: £1500+
