APC Smart-UPS protects your data by supplying reliable, network-grade power in either traditional Tower or Rack-optimized form factors for space constrained business critical applications. Award winning APC Smart-UPS is the perfect UPS for protecting business critical fileservers (Intel or UNIX based), minicomputers, network switches and hubs, Point of Sale, retail/bank back office and ATMs. Rack Mount versions are the choice for rack optimized servers, server appliances, blade servers, other blade devices and rack-mounted network switches and hubs.
- APC Smart-UPS 3000VA LCD RM - UPS - 2700 Watt - 3000 VA - with APC UPS Network Management Card
- UPS - rack-mountable
- Rack Size
- 2U
- 44.19 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 2700 Watt / 3000 VA
- Input Connectors
- 1
- Output connectors
- 8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
- Battery
- Lead Acid
- Run Time (Up To)
- 3.2 min at full load
- Networking
- Ethernet, RS-232, USB
- Included Accessories
- Rack mounting rails, temperature probe
- Black
- 48 cm x 68.3 cm x 8.6 cm
- 3-year warranty
- Bundled with
- APC UPS Network Management Card
- Designed For
- P/N: AR2200, AR2280, AR2487G, AR3100TAA, AR3100W, AR3105SP, AR3105W, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR4038IX432, NBPD0180, NBWL0356A
- Height (Rack Units)
- 2U
- Black
- Bundled with
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 47 - 63 Hz
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 47 - 63 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 320 Joules
- Circuit Protection
- Circuit breaker
- Technology
- Lead Acid
- Run Time (Up To)
- 3.2 min at full load , 11.5 min at half load
- Recharge Time
- 3 hours
- Transfer Time
- 4 ms
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- 1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (Ethernet) - RJ-45
- Expansion Slots
- 1 (total) / 0 (free) x SmartSlot
- Cables Included
- Serial cable - external , USB cable - external , Power cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
- GS, VDE, IEC 62040-2, IRAM, RoHS, WEEE, REACH, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 55 dBA
- 48 cm
- 68.3 cm
- 8.6 cm
- 44.19 kg
- Shipping Width
- 60 cm
- Shipping Depth
- 98 cm
- Shipping Height
- 25.4 cm
- Shipping Weight
- 51.59 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF202BLK, ACF400, ACF402, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR201, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3180G, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, NBPD0180, NBRK0201, NBRK0320, NBRK0320E, NBRK0551, NBWL0355, NBWL0356A
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.86 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £50.84 |
APC - Power cable - Male-Female - 1.98 m | In Stock | £50.45 |
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £203.49 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.38 |
APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid | In Stock | £429.65 |
APC Power cable - 2.4 m | In Stock | £85.33 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £296.28 |
APC 3Yr Extended Warranty SP | In Stock | £323.96 |
APC Temperature and Humidity Sensor | In Stock | £132.71 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £285.81 |
APC Smart-UPS X 120V EXT BATTERY | In Stock | £931.88 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £977.33 |
APC Power Cord Locking C19 to C20 3.0m | In Stock | £70.04 |
APC Power Cord, C19 to CEE/7 Schuko, 2.5m | In Stock | £55.11 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.88 |
APC Power Cable (pack of 6) 1.22m | In Stock | £88.51 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £130.53 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £105.93 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £632.56 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £760.50 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.68 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £702.09 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,249.04 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.00 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £467.04 |
