APC Smart UPS 2200VA LCD RM 2U 230
Quicklinx: F0G2WS00 Mfr#: SMT2200RMI2UC
Type: UPS
Power Rating: 1980Watt
27 In Stock
£1,540.61 ex VAT
£1,848.73 inc VAT
Marketing description is not available.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Sequenced network shutdown and reboot
    Customize network shutdown and reboot sequence of connected servers and UPSs.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • StruxureWare Data Center Expert compatible
    Enables centralized management via StruxureWare Data Center Expert.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMT 2200VA LCD RM with SmartConnect - UPS - 1980 Watt - 2200 VA
UPS - rack-mountable
Rack Size
2U
42.31 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V
Power Capacity
1980 Watt / 2200 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
8 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Batteries Qty
1
Run Time (Up To)
5 min at full load
RS-232, USB
48 cm x 68.3 cm x 8.6 cm
P/N: AR3003, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3357X674, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
Height (Rack Units)
2U
UPS Technology
On-line
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 150 - 300 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 220/230/240 V 50/60 Hz
Power Capacity
1980 Watt / 2200 VA
Output Waveform
Sinewave
Surge Suppression
Quantity
1
Lead Acid
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Audible alarm, LCD display
VDE, EN 62040-2, EAC, RCM, EN 62040-1
Software Included
APC PowerChute Business Edition
48 cm
68.3 cm
8.6 cm
42.31 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF002, ACF101BLK, ACF102BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X432, AR7007, AR7050, AR7057, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, NBWL0356A
F0G2 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.69
F0G2 APC - Power cable - Male-Female - 1.98 m In Stock £51.34
F0G2 APC Basic Rack-Mount PDU - power distribution strip In Stock £203.85
F0G2 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.98
F0G2 APC Replacement Battery Cartridge #43 - UPS battery - Lead Acid In Stock £434.82
F0G2 APC Power cable - 2.4 m In Stock £86.26
F0G2 APC Rack PDU Basic Zero U 16A 208/230V In Stock £298.78
F0G2 APC 2-Post Mounting Kit for Smart-UPS In Stock £175.84
F0G2 APC 3Yr Extended Warranty SP In Stock £328.37
F0G2 APC Temperature and Humidity Sensor In Stock £134.43
F0G2 APC POWER CORD C13 TO C20 1.98m Black In Stock £52.50
F0G2 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £288.97
F0G2 APC APC POWERCORD C19 TO C20 1.8M In Stock £185.46
F0G2 APC Power Cord Locking C19 to IEC309-16A 3.0m In Stock £84.91
F0G2 APC Power Cord Locking C19 to C20 3.0m In Stock £69.94
F0G2 APC Power Cord, C19 to CEE/7 Schuko, 2.5m In Stock £53.64
F0G2 APC Power Cable (pack of 6) 1.22m In Stock £88.25
F0G2 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £131.99
F0G2 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £633.65
F0G2 APC Extended Warranty Service Pack Technical Support 1 Year In Stock £137.26
F0G2 APC Metered Rack PDU In Stock £850.13
F0G2 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £749.97
F0G2 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £60.99
F0G2 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £674.28
F0G2 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,263.27
F0G2 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £162.41
F0G2 APC Rack PDU Basic 0U/1U 100-240V/ In Stock £82.68
Type: UPS
Brand: APC
Price Range Ex VAT: £1500+
