APC Smart-UPS 1500VA RM 230V w/Network Card
Quicklinx: CR30WS00 Mfr#: SMT1500RMI2UNC
Power Rating: 1kW, 1kW
32 in stock
£866.76 ex VAT
£1,040.11 inc VAT
Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
Predictive replace battery date dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Preinstalled network management card
    Provides for remote management and control of the UPS over a network out of the box
APC Smart-UPS 1500VA LCD RM - UPS - 1 kW - 1500 VA - with APC UPS Network Management Card
UPS - rack-mountable
Rack Size
2U
28.58 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
1 kW / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
Power IEC 60320 C13
Lead Acid
Run Time (Up To)
7 min at full load
Ethernet, RS-232, USB
Rack mounting rails, temperature probe
43.2 cm x 45.7 cm x 8.9 cm
3-year warranty
Bundled with
Height (Rack Units)
2U
Bundled with
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50 Hz ± 3Hz
Input Connectors
Power IEC 60320 C13
Output Voltage
AC 230 V ± 5%
Power Capacity
1 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
7 min at full load , 26 min at half load
Recharge Time
3 hours
Switchover Time
2 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (USB) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
VDE, IEC 62040-2, RoHS, REACH, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
45.7 cm
8.9 cm
28.58 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.84 kg
Power Rating: 1kW
Power Rating: 1kW
Brand: APC
Price Range Ex VAT: 750 - 1000
