APC Smart-UPS 1500VA RM 230V w/Network Card
Quicklinx: CR30WS00 Mfr#: SMT1500RMI2UNC
Power Rating: 1000watt
17 In Stock
£1,189.09 ex VAT
£1,426.90 inc VAT
Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
Predictive replace battery date dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Preinstalled network management card
    Provides for remote management and control of the UPS over a network out of the box
APC Smart-UPS 1500VA LCD RM - UPS - 1000 watt - 1500 VA - with APC UPS Network Management Card
UPS - rack-mountable
Rack Size
2U
28.58 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
1000 watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
Power IEC 60320 C13
Lead Acid
Run Time (Up To)
7 min at full load
Ethernet, RS-232, USB
Rack mounting rails, temperature probe
43.2 cm x 45.7 cm x 8.9 cm
3-year warranty
Bundled with
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
Bundled with
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Required
50 Hz ± 3Hz
Input Connectors
Power IEC 60320 C13
Output Voltage
AC 230 V ± 5%
Power Capacity
1000 watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
7 min at full load , 26 min at half load
Recharge Time
3 hours
Transfer Time
2 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
1 x management (RS-232) - RJ-45 , 1 x management (USB) - 4 pin USB Type B , Management (USB) - RJ-45
Expansion Slots
1 (total) / 0 (free) x SmartSlot
Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
VDE, IEC 62040-2, RoHS, REACH, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
45.7 cm
8.9 cm
28.58 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.84 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF202BLK, ACF400, ACF402, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR201, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3180G, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3810, AR3812, AR3814, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, NBPD0180, NBRK0201, NBRK0320, NBRK0320E, NBRK0551, NBWL0355, NBWL0356A
CR30 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.45
CR30 APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £51.81
CR30 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.95
CR30 APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.25
CR30 APC Temperature and Humidity Sensor In Stock £130.54
CR30 APC Smart-UPS X 120V EXT BATTERY In Stock £926.40
CR30 APC Replacement Battery Cartridge In Stock £307.28
CR30 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £58.60
CR30 APC Power Cable (pack of 6) 1.22m In Stock £90.04
CR30 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.11
CR30 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £103.89
CR30 APC Extended Warranty Service Pack 3 Year In Stock £162.47
CR30 APC Service Pack 1 Year Warranty Extension In Stock £79.80
CR30 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.95
CR30 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £683.92
CR30 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.62
Brand: APC
Price Range Ex VAT: £1000 - £1500
