APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks.
Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption.
Rack mounted Smart-UPS are ideal for powering blade or density optimized servers in a distributed power protection environment as the primary or redundant protection. Smart-UPS features a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
Alphanumeric LCD (Liquid Crystal Display) Intuitive interface provides detailed and accurate information with the ability to configure locally.
Communication Ports: Serial, USB, and SmartSlot™ for accessory cards.
4 IEC320 C13 Outlets
Push Button Circuit Breaker enables quick recovery from overloads.
Network-grade Power: Provides most stable power conditions by filtering noise, automatic voltage regulation (AVR), and surge protection.
High Efficiency Green Mode: Saves utility costs and reduces heat promoting longer component life.
Advanced Battery Management: Temperature-compensated charging extends life and advanced algorithms recommend replacement date
Smart-UPS Display
Intuitive, easy-to-use LCD interface
LCD Display Screen - Clear, consistent, and detailed information in your choice of basic or advanced menus.
Power Status:
Operating mode and efficiency
Load VA/Watts/Amps
Input/Output voltage and frequency
Battery capacity and runtime
Energy meter and more
Control: - UPS and outlet group settings
Configuration:
Language
Power quality settings
Alarm, delay and threshold settings
Test and Diagnostics: - Initiate battery and runtime calibration tests
Logs: - See explanation of last 10 transfers and faults
About: - UPS and replacement battery part numbers, serial numbers, battery install, and suggested replacement dates
Online Status Indicators: - Online, on battery, fault, and replace battery LEDs for quick status identification.
Cold-start capable
Provides temporary battery power when the utility power is out. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High online efficiency
Reduces utility costs, generates less heat. -
Intelligent Card Slot
Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS 1500 LCD - UPS - 1 kW - 1500 VA
- UPS - rack-mountable
- Rack Size
- 2U
- 28.6 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 1 kW / 1500 VA
- Input Connectors
- Power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13
- Battery
- Lead Acid
- Run Time (Up To)
- 7.2 min at full load
- Networking
- RS-232, USB
- Black
- 43.2 cm x 45.7 cm x 8.9 cm
- 3-year warranty
- Designed For
- P/N: AR3105W, AR3140G, AR3155W, AR3305W, AR3340G, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A, SCL500RM1UC, SCL500RM1UNC, SMTL1000RM2UC, SMTL750RM2UC, SYAF8KRMTX424
- Height (Rack Units)
- 2U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 57 - 63 Hz
- Frequency Required
- 47/63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 57 - 63 Hz
- Power Capacity
- 1 kW / 1500 VA
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 Joules
- Technology
- Lead Acid
- Run Time (Up To)
- 7.2 min at full load , 25.8 min at half load
- Recharge Time
- 3 hours
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) , 1 x management (USB)
- Expansion Slots
- 1 SmartSlot
- Cables Included
- Serial cable , USB cable
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function
- TUV, C-Tick, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1, REACH
- Software Included
- Drivers & Utilities
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 46 dBA
- 43.2 cm
- 45.7 cm
- 8.9 cm
- 28.6 kg
- Shipping Width
- 59.4 cm
- Shipping Depth
- 60.3 cm
- Shipping Height
- 25.1 cm
- Shipping Weight
- 31.9 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A, SCL500RM1UC, SCL500RM1UNC, SMTL1000RM2UC, SMTL750RM2UC, SYAF8KRMTX424
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £28.73 |
APC Temperature and Humidity Sensor | In Stock | £147.76 |
APC Replacement Battery Cartridge | In Stock | £295.94 |
APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £55.91 |
APC Dry Contact I/O SmartSlot Card | In Stock | £172.83 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £128.98 |
APC Extended Warranty Service Pack 3 Year | In Stock | £150.29 |
APC Service Pack 1 Year Warranty Extension | In Stock | £70.73 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £645.61 |
