APC Smart-UPS 1500VA LCD RM 2U 230V
Quicklinx: 7GWDWS00 Mfr#: SMT1500RMI2U
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks.
Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption.
Rack mounted Smart-UPS are ideal for powering blade or density optimized servers in a distributed power protection environment as the primary or redundant protection. Smart-UPS features a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  1. Alphanumeric LCD (Liquid Crystal Display) Intuitive interface provides detailed and accurate information with the ability to configure locally.
  2. Communication Ports: Serial, USB, and SmartSlot™ for accessory cards.
  3. 4 IEC320 C13 Outlets
  4. Push Button Circuit Breaker enables quick recovery from overloads.
  5. Network-grade Power: Provides most stable power conditions by filtering noise, automatic voltage regulation (AVR), and surge protection.
  6. High Efficiency Green Mode: Saves utility costs and reduces heat promoting longer component life.
  7. Advanced Battery Management: Temperature-compensated charging extends life and advanced algorithms recommend replacement date
Smart-UPS Display
Intuitive, easy-to-use LCD interface
LCD Display Screen - Clear, consistent, and detailed information in your choice of basic or advanced menus.
Power Status:
Operating mode and efficiency
Load VA/Watts/Amps
Input/Output voltage and frequency
Battery capacity and runtime
Energy meter and more
Control: - UPS and outlet group settings
Configuration:
Language
Power quality settings
Alarm, delay and threshold settings
Test and Diagnostics: - Initiate battery and runtime calibration tests
Logs: - See explanation of last 10 transfers and faults
About: - UPS and replacement battery part numbers, serial numbers, battery install, and suggested replacement dates
Online Status Indicators: - Online, on battery, fault, and replace battery LEDs for quick status identification.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 1500 LCD - UPS - 1 kW - 1500 VA
UPS - rack-mountable
Rack Size
2U
28.6 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
1 kW / 1500 VA
Input Connectors
Power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Run Time (Up To)
7.2 min at full load
RS-232, USB
43.2 cm x 45.7 cm x 8.9 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
57 - 63 Hz
Frequency Required
47/63 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 57 - 63 Hz
Power Capacity
1 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 joules
Lead Acid
Run Time (Up To)
7.2 min at full load , 25.8 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x management (USB)
Expansion Slots
1 SmartSlot
Serial cable , USB cable
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), cold-start function
TUV, C-Tick, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
45.7 cm
8.9 cm
28.6 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.9 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
7GWD APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.76
7GWD APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £54.79
7GWD APC 2-Post Mounting Kit for Smart-UPS In Stock £180.14
7GWD APC Temperature and Humidity Sensor In Stock £132.19
7GWD APC Replacement Battery Cartridge In Stock £311.06
7GWD APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £60.26
7GWD APC Power Cable (pack of 6) 1.22m In Stock £90.09
7GWD APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £133.99
7GWD APC Extended Warranty Service Pack 3 Year In Stock £163.77
7GWD APC Service Pack 1 Year Warranty Extension In Stock £80.71
7GWD APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.93
7GWD APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
7GWD APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.18
