APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Rack mounted Smart-UPS are ideal for powering blade or density optimized servers in a distributed power protection environment as the primary or redundant protection. Smart-UPS features a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics -
Cold-start capable
Provides temporary battery power when the utility power is out -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
High online efficiency
Reduces utility costs, generates less heat -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning -
SmartSlot
Customize UPS capabilities with management cards -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users -
Multiple switched outlet groups
Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding -
High frequency design
Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
- APC Smart-UPS 1500 LCD - UPS - 1000 watt - 1500 VA
- UPS - rack-mountable
- Rack Size
- 1U
- 24.09 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 1000 watt / 1500 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 4 x power IEC 60320 C13 , 2 x IEC jumper
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 4.8 min at full load
- Networking
- RS-232, USB
- Black
- 43.2 cm x 66.5 cm x 44 cm
- 3-year warranty
- Designed For
- P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
- Height (Rack Units)
- 1U
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5%
- Max Electric Current
- 12 A
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 540 joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 4.8 min at full load , 16.6 min at half load
- Recharge Time
- 4 hour(s)
- Maintenance free, sealed, leak-proof
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) - RJ-45 , 1 x USB - 4 pin USB Type B
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Power cable - external - 2.44 m , Serial cable - external , USB cable - external
- Rack Mounting Kit
- Included
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test
- UL 1449, RoHS, REACH
- Software Included
- APC PowerChute Business Edition
- Limited warranty - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 46 dBA
- 43.2 cm
- 66.5 cm
- 44 cm
- 24.09 kg
- Shipping Width
- 57.5 cm
- Shipping Depth
- 79.4 cm
- Shipping Height
- 20 cm
- Shipping Weight
- 29.09 kg
- Designed For
- P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £204.72 |
APC 1U Vertical Cable Organiser | In Stock | £124.46 |
APC 1U Horizontal Cable Organiser | In Stock | £55.31 |
APC Netshelter heavy duty shelf | In Stock | £141.57 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £301.67 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £325.19 |
APC Temperature and Humidity Sensor | In Stock | £129.89 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £288.18 |
APC Cable Managers (Qty 10) | In Stock | £36.26 |
APC 2G Power distribution strip | In Stock | £648.12 |
APC Rack PDU 2G METERED ZEROU | In Stock | £691.53 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £510.38 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £997.60 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £956.91 |
APC 19" Rack LCD Console | In Stock | £1,377.48 |
APC Vertical Cable Organizer, NetShelter SX, 42U | In Stock | £94.27 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £80.70 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,509.19 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £98.76 |
APC 1U Blanking Panel Kit | In Stock | £34.70 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £55.86 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.73 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,638.60 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £68.89 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £636.51 |
APC Extended Warranty Service Pack 3 Year | In Stock | £159.86 |
APC Metered Rack PDU | In Stock | £854.08 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £265.48 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,094.45 |
APC Service Pack 1 Year Warranty Extension | In Stock | £79.26 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £61.98 |
APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ | In Stock | £1,204.72 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £676.02 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,258.00 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £162.67 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,302.58 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.13 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £457.51 |
