APC Smart-UPS 1500VA LCD RM 1U 230V
Quicklinx: 9RVPWS00 Mfr#: SMT1500RMI1U
Type: UPS
Power Rating: 1000watt
£974.58 ex VAT
£1,169.49 inc VAT
APC award-winning Smart-UPS is the most popular UPS in the world for servers, storage and networks. Trusted to protect critical data and equipment from power problems by supplying clean and reliable network-grade power. In addition to legendary reliability and manageability, Smart-UPS have extremely high efficiency at low, medium and high load levels making them ideal for today's multi-core or virtualized servers that have varying load consumption. Rack mounted Smart-UPS are ideal for powering blade or density optimized servers in a distributed power protection environment as the primary or redundant protection. Smart-UPS features a 16-segment LED display, extended range automatic voltage regulation (AVR), and pure sine wave output on battery.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • High online efficiency
    Reduces utility costs, generates less heat
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning
  • SmartSlot
    Customize UPS capabilities with management cards
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users
  • Multiple switched outlet groups
    Multiple outlet groups that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding
  • High frequency design
    Reduces or eliminates bulky transformers resulting in lighter units for ease of handling
APC Smart-UPS 1500 LCD - UPS - 1000 watt - 1500 VA
UPS - rack-mountable
Rack Size
1U
24.09 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V ± 5%
Power Capacity
1000 watt / 1500 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Batteries Qty
1
Run Time (Up To)
4.8 min at full load
RS-232, USB
43.2 cm x 66.5 cm x 44 cm
3-year warranty
P/N: AR2487G, AR3100W, AR3105SP, AR3105W, AR3140G, AR3140W, AR3150W, AR3155SP, AR3155W, AR3300W, AR3305W, AR3340G, AR3355SP, AR3355W, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
1U
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 230 V ± 5%
Max Electric Current
12 A
Power Capacity
1000 watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
540 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
4.8 min at full load , 16.6 min at half load
Recharge Time
4 hour(s)
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) - RJ-45 , 1 x USB - 4 pin USB Type B
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Power cable - external - 2.44 m , Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators, cold-start function, automatic self-test
UL 1449, RoHS, REACH
Software Included
APC PowerChute Business Edition
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
66.5 cm
44 cm
24.09 kg
Shipping Width
57.5 cm
Shipping Depth
79.4 cm
Shipping Height
20 cm
Shipping Weight
29.09 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X431, AR4038X432, AR7007, AR7050, AR7057, AR8135BLK, NBWL0356A
9RVP APC Basic Rack-Mount PDU - power distribution strip In Stock £205.26
9RVP APC 1U Vertical Cable Organiser In Stock £124.13
9RVP APC 1U Horizontal Cable Organiser In Stock £55.67
9RVP APC Netshelter heavy duty shelf In Stock £142.64
9RVP APC Rack PDU Basic Zero U 16A 208/230V In Stock £303.96
9RVP APC Rack PDU Basic Zero U 32A 230V In Stock £327.65
9RVP APC Temperature and Humidity Sensor In Stock £130.76
9RVP APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £295.10
9RVP APC Cable Managers (Qty 10) In Stock £36.51
9RVP APC 2G Power distribution strip In Stock £652.33
9RVP APC Rack PDU 2G METERED ZEROU In Stock £694.72
9RVP APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £514.24
9RVP APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,004.29
9RVP APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £963.35
9RVP APC 19" Rack LCD Console In Stock £1,378.53
9RVP APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £94.99
9RVP APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.26
9RVP APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,510.33
9RVP APC NetShelter Zero U Accessory Mounting Bracket In Stock £98.59
9RVP APC 1U Blanking Panel Kit In Stock £34.92
9RVP APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.44
9RVP APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.98
9RVP APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,674.94
9RVP APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.35
9RVP APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £640.79
9RVP APC Extended Warranty Service Pack 3 Year In Stock £161.07
9RVP APC Metered Rack PDU In Stock £850.25
9RVP APC Switched Rack PDU AC 208-230 V Ethernet In Stock £763.47
9RVP APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £266.89
9RVP APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,101.80
9RVP APC Service Pack 1 Year Warranty Extension In Stock £79.80
9RVP APC Replacement Battery Cartridge #88 In Stock £309.65
9RVP APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.39
9RVP APC Rack PDU 2G Metered-by-Outlet ZeroU 32A 230V (21) C13+(3)$ In Stock £1,220.80
9RVP APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £681.13
9RVP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,267.52
9RVP APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £163.89
9RVP APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,311.33
9RVP APC Rack PDU Basic 0U/1U 100-240V/ In Stock £84.53
9RVP APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.34
Type: UPS
Brand: APC
Price Range Ex VAT: £750 - £1000
