APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable)
Quicklinx: DJKLWS00 Mfr#: SMT1500RMI2UC
Type: UPS
Power Rating: 1000watt
More than 50 In Stock
£903.39 ex VAT
£1,084.06 inc VAT
Intuitive LCD interface provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
Predictive replace battery date dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Software package
    SmartConnect software for remote power monitoring feature availability varies by terms of use
  • Communication port support
    SmartConnect Ethernet port for cloud monitoring feature availability varies by terms of use
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 1500VA LCD RM - UPS - 1000 watt - 1500 VA - with APC SmartConnect
UPS - rack-mountable
Rack Size
2U
26.1 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 220/230/240 V
Power Capacity
1000 watt / 1500 VA
Input Connectors
Power IEC 60320 C14
Output connectors
4 x power IEC 60320 C13
Lead Acid
Run Time (Up To)
7.2 min at full load
RS-232, USB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, SSH-2
43.2 cm x 47.7 cm x 8.6 cm
Environmental Standards
ENERGY STAR
3-year warranty
Bundled with
APC SmartConnect
P/N: AR106V, AR106VI, AR112SH6, AR3003SP, AR3006, AR3006SP, AR3103, AR3103SP, AR3106, AR3106SP, AR3140G, AR3340G, AR3355W, AR3357X674, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBWL0356A
Height (Rack Units)
2U
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 220/230/240 V 57 - 63 Hz
Power Capacity
1000 watt / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 joules
Circuit Protection
Circuit breaker
Lead Acid
Run Time (Up To)
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - RJ-45
Expansion Slots
1 SmartSlot
Serial cable , USB cable
Rack Mounting Kit
Included
Audible alarm, LCD display, Automatic Voltage Regulation (AVR), LED indicators
UL 1778, VDE, CSA, EAC, RCM, EN 62040-1, EN 62040-2, IEC 62040-1, IEC 62040-2
Software Included
APC PowerChute Business Edition
Sustainability Information
ENERGY STAR
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
46 dBA
43.2 cm
47.7 cm
8.6 cm
26.1 kg
Shipping Width
59.4 cm
Shipping Depth
60.3 cm
Shipping Height
25.1 cm
Shipping Weight
31.91 kg
P/N: ACCS1000, ACCS1001, ACCS1002, ACCS1003, ACCS1004, ACCS1005, ACCS1006, ACCS1007, ACDC1015, ACDC1016, ACDC1017, ACDC1019, ACDC1020, ACDC1021, ACDC2513, ACF001, ACF002, ACF003, ACF101BLK, ACF102BLK, ACF201BLK, ACF400, ACF600, AP5017, AP5602, AP5606, AP5607, AP5616, AP92200, AP9290, AR100, AR100HD, AR106V, AR106VI, AR112SH6, AR202, AR203A, AR204A, AR2101, AR2102BLK, AR2144BLK, AR2145BLK, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR2900, AR2901, AR3000, AR3003SP, AR3006, AR3006SP, AR3100, AR3100G, AR3100SP, AR3100SP1, AR3100SP2, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3101, AR3103, AR3103SP, AR3104, AR3104SP1, AR3105, AR3105SP, AR3105W, AR3106, AR3106SP, AR3107, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140, AR3140G, AR3140W, AR3150, AR3150SP, AR3150SP1, AR3150SP2, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3200, AR3300, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, AR4018, AR4018A, AR4018I, AR4018IA, AR4018IX429, AR4018IX431, AR4018IX432, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4018X431, AR4018X432, AR4024, AR4024A, AR4024I, AR4024IA, AR4024IX429, AR4024IX431, AR4024IX432, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4024X429, AR4024X431, AR4024X432, AR4038, AR4038A, AR4038I, AR4038IA, AR4038IX429, AR4038IX431, AR4038IX432, AR4038X429, AR4038X432, AR7007, AR7050, AR7057, NBWL0356A
DJKL APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £30.51
DJKL APC Power Cord IEC 320 C19 TO IEC 320 C14 In Stock £50.04
DJKL APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.95
DJKL APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.09
DJKL APC 2-Post Mounting Kit for Smart-UPS In Stock £175.48
DJKL APC Temperature and Humidity Sensor In Stock £130.54
DJKL APC Power Cable (pack of 6) 1.22m In Stock £90.23
DJKL APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.53
DJKL APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £104.13
DJKL APC Extended Warranty Service Pack 3 Year In Stock £161.66
DJKL APC Service Pack 1 Year Warranty Extension In Stock £79.67
DJKL APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.92
DJKL APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £689.02
DJKL APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £467.09
Type: UPS
Brand: APC
Price Range Ex VAT: £750 - £1000
