APC Smart-UPS 1500VA LCD 230V
Quicklinx: 78FXWS00 Mfr#: SMT1500I
Green mode bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. Energy meter provides actual kilowatt hours of usage for energy conscious users. Intuitive LCD interface provides clear and accurate information with the ability to configure the UPS locally with easy to use navigation keys. Single switched outlet group may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on / off and non-critical load shedding. Pure sine wave output on battery simulates utility power to provide a high degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. Cold-start capable provides temporary battery power when the utility power is out.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Intelligent Card Slot
    Customize UPS capabilities with management cards.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS 1500 LCD - UPS - 1 kW - 1500 VA
UPS - external
24.1 kg
Input Voltage
AC 230 V
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
1 kW / 1500 VA
Input Connectors
Power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Batteries Qty
1
Run Time (Up To)
6.7 min at full load
RS-232, USB
17.1 cm x 43.9 cm x 21.9 cm
3-year warranty
UPS - external
UPS Technology
Line interactive
Input Voltage
AC 230 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
47 - 53 / 57 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 220/230/240 V ± 5% - 47 - 53 / 57 - 63 Hz
Power Capacity
1 kW / 1500 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
6.7 min at full load , 23.9 min at half load
Recharge Time
3 hours
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x management (USB)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Serial cable - external , USB cable - external , Power cable - external - 1.8 m
Audible alarm, LCD display, cold-start function
C-Tick, UL 1449, VDE, EN 50091-2, RoHS Exemption 7b, EN 50091-1, REACH
Software Included
Drivers & Utilities
Limited warranty - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
45 dBA
17.1 cm
43.9 cm
21.9 cm
24.1 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
27.2 kg
78FX APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £28.90
78FX APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £50.88
78FX APC Replacement Battery Cartridge #7 - UPS battery - Lead Acid In Stock £242.21
78FX APC Temperature and Humidity Sensor In Stock £130.81
78FX APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £56.28
78FX APC Power Cable (pack of 6) 1.22m In Stock £84.43
78FX APC Dry Contact I/O SmartSlot Card In Stock £165.13
78FX APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £126.10
78FX APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £100.67
78FX APC Extended Warranty Service Pack 3 Year In Stock £146.46
78FX APC Service Pack 1 Year Warranty Extension In Stock £69.20
78FX APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £59.34
78FX APC Switched PDU 10A 0U C13x16 In Stock £1,129.15
78FX APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £668.72
