APC Smart-UPS 1000VA LCD 230V
Quicklinx: G4Z4WS00 Mfr#: SMT1000IC
Power Rating: 700Watt
More than 50 In Stock
£519.37 ex VAT
£623.24 inc VAT
Intelligent and efficient network power protection from entry level to scalable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
  • Cold-start capable
    Provides temporary battery power when the utility power is out.
  • Energy meter
    Provides actual kilowatt hours of usage for energy conscious users.
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection.
  • High online efficiency
    Reduces utility costs, generates less heat.
  • Intelligent Card Slot
    Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS.
  • Intuitive LCD interface
    Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys.
  • Predictive replace battery date
    Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning.
  • Pure sine wave output on battery
    Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics.
  • Single switched outlet group
    Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding.
  • SmartConnect
    Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services.
  • Temperature-compensated battery charging
    Prolongs battery life by regulating the charge voltage according to battery temperature.
APC Smart-UPS SMT1000IC - UPS - 700 Watt - 1000 VA - with APC SmartConnect
UPS - external
18.86 kg
Input Voltage
AC 220/230/240 V
Output Voltage
AC 230 V ± 5%
Power Capacity
700 Watt / 1000 VA
Input Connectors
1 x power IEC 60320 C14
Output connectors
8 x power IEC 60320 C13 , 2 x IEC jumper
Lead Acid
Batteries Qty
1
Run Time (Up To)
5.8 min at full load
RS-232, USB
17.1 cm x 43.9 cm x 21.9 cm
3-year warranty
Bundled with
APC SmartConnect
UPS - external
Bundled with
APC SmartConnect
UPS Technology
Line interactive
Input Voltage
AC 220/230/240 V
Input Voltage Range
AC 160 - 286 V
Input Voltage Range (Adjustable)
AC 151 - 302 V
Frequency Provided
50/60 Hz ± 3Hz
Frequency Required
50/60 Hz ± 3Hz
Input Connectors
Output Voltage
AC 230 V ± 5% - 50/60 Hz
Power Capacity
700 Watt / 1000 VA
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
459 Joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
5.8 min at full load , 19.1 min at half load , 183 min at 50 Watts , 100 min at 100 Watts , 45.2 min at 200 Watts , 24.7 min at 300 Watts , 15 min at 400 Watts , 9.8 min at 500 Watts , 7.1 min at 600 Watts , 5.8 min at 700 Watts
Recharge Time
3 hours
Transfer Time
6 ms
Maintenance free, sealed, leak-proof
Remote Management Interface
RS-232, USB
1 x management (RS-232) , 1 x USB , 1 x EPO (emergency power off)
Expansion Slots
1 (total) / 1 (free) x SmartSlot
Network cable - external , USB cable - external
Audible alarm, emergency power off, LCD display, Automatic Voltage Regulation (AVR), cold-start function, automatic self-test, predicitive failure notification, hot-swappable batteries, energy metre
CSA, UL 1778, VDE, IEC 62040-2, EN 62040-2, EAC, RCM, IEC 62040-1, EN 62040-1
Software Included
APC PowerChute Business Edition
Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
0 - 95%
Sound Emission
41 dBA
17.1 cm
43.9 cm
21.9 cm
18.86 kg
Shipping Width
32.8 cm
Shipping Depth
59.5 cm
Shipping Height
37.6 cm
Shipping Weight
22.77 kg
G4Z4 APC Power Cord IEC 320 C13 to IEC 320 C14 In Stock £31.01
G4Z4 APC Pwr Cord, 10A, 230V, C14 to UK rec In Stock £53.98
G4Z4 APC BackUPS+SmartUPS 1000 Battery In Stock £211.37
G4Z4 APC Temperature and Humidity Sensor In Stock £133.36
G4Z4 APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £59.63
G4Z4 APC Power Cable (pack of 6) 1.22m In Stock £89.53
G4Z4 APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £132.46
G4Z4 APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m In Stock £106.06
G4Z4 APC 1 Year Extended Warranty 2015-4037 In Stock £63.57
G4Z4 APC Service Pack 3 Year Warranty Extension In Stock £119.50
G4Z4 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.38
G4Z4 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £675.56
G4Z4 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £472.50
Brand: APC
Price Range Ex VAT: £500 - £750
