Intelligent and efficient network power protection from entry level to scalable runtime. Ideal UPS for servers, point-of-sale, routers, switches, hubs and other network devices.
Cold-start capable
Provides temporary battery power when the utility power is out. -
Energy meter
Provides actual kilowatt hours of usage for energy conscious users. -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection. -
High online efficiency
Reduces utility costs, generates less heat. -
Intelligent Card Slot
Mini slot supports various optional management cards which provide basic or essential monitoring, management and control features for the UPS. -
Intuitive LCD interface
Provides clear and accurate information in multiple languages with the ability to configure the UPS locally with easy to use navigation keys. -
Predictive replace battery date
Dynamically provides the month and year when battery replacement is recommended to aide in long term maintenance planning. -
Pure sine wave output on battery
Simulates utility power to provide the highest degree of compatibility for active PFC (power factor corrected) servers and sensitive electronics. -
Single switched outlet group
Single outlet group that may be controlled separately from the UPS for discrete reboot of hung devices, sequenced on/off and non-critical load shedding. -
SmartConnect
Innovative, easy to use remote monitoring feature that provides automatic notifications, firmware updates, and advanced support services. -
Temperature-compensated battery charging
Prolongs battery life by regulating the charge voltage according to battery temperature.
- APC Smart-UPS SMT1000IC - UPS - 700 watt - 1000 VA - with APC SmartConnect
- UPS - external
- 18.86 kg
- Input Voltage
- AC 220/230/240 V
- Output Voltage
- AC 230 V ± 5%
- Power Capacity
- 700 watt / 1000 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 8 x power IEC 60320 C13 , 2 x IEC jumper
- Battery
- Lead Acid
- Batteries Qty
- 1
- Run Time (Up To)
- 5.8 min at full load
- Networking
- RS-232, USB
- Black
- 17.1 cm x 43.9 cm x 21.9 cm
- 3-year warranty
- Bundled with
- APC SmartConnect
- UPS - external
- Black
- Bundled with
- APC SmartConnect
- UPS Technology
- Line interactive
- Input Voltage
- AC 220/230/240 V
- Input Voltage Range
- AC 160 - 286 V
- Input Voltage Range (Adjustable)
- AC 151 - 302 V
- Frequency Provided
- 50/60 Hz ± 3Hz
- Frequency Required
- 50/60 Hz ± 3Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V ± 5% - 50/60 Hz
- Power Capacity
- Output Waveform
- Sinewave
- Surge Suppression
- Surge Energy Rating
- 459 joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Technology
- Lead Acid
- Run Time (Up To)
- 5.8 min at full load , 19.1 min at half load , 183 min at 50 Watts , 100 min at 100 Watts , 45.2 min at 200 Watts , 24.7 min at 300 Watts , 15 min at 400 Watts , 9.8 min at 500 Watts , 7.1 min at 600 Watts , 5.8 min at 700 Watts
- Recharge Time
- 3 hours
- Transfer Time
- 6 ms
- Leak-proof, maintenance free, sealed
- Remote Management Interface
- RS-232, USB
- 1 x management (RS-232) , 1 x USB , 1 x EPO (emergency power off)
- Expansion Slots
- 1 (total) / 1 (free) x SmartSlot
- Cables Included
- Network cable - external , USB cable - external
- Cold-start function, energy metre, LCD display, automatic self-test, Automatic Voltage Regulation (AVR), hot-swappable batteries, predicitive failure notification, audible alarm, emergency power off
- CSA, EAC, IEC 62040-1, EN 62040-1, IEC 62040-2, EN 62040-2, RCM, UL 1778, VDE
- Software Included
- APC PowerChute Business Edition
- Limited warranty - replace or repair - 3 years , Limited warranty - batteries - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 41 dBA
- 17.1 cm
- 43.9 cm
- 21.9 cm
- 18.86 kg
- Shipping Width
- 32.8 cm
- Shipping Depth
- 59.5 cm
- Shipping Height
- 37.6 cm
- Shipping Weight
- 22.77 kg
APC Power Cord IEC 320 C13 to IEC 320 C14 | In Stock | £30.40 |
APC Power Cord IEC 320 C19 TO IEC 320 C14 | In Stock | £50.12 |
APC Pwr Cord, 10A, 230V, C14 to UK rec | In Stock | £53.80 |
APC BackUPS+SmartUPS 1000 Battery | In Stock | £214.28 |
APC Temperature and Humidity Sensor | In Stock | £130.76 |
APC Power Cable (pack of 6) 1.22m | In Stock | £90.18 |
APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £132.09 |
APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £103.59 |
APC 1 Year Extended Warranty 2015-4037 | In Stock | £62.36 |
APC Service Pack 3 Year Warranty Extension | In Stock | £116.57 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.39 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £681.13 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £459.61 |
