APC Replacement Battery Cartridge RBC55
Quicklinx: 533TWS00 Mfr#: RBC55
£441.92 ex VAT
£530.30 inc VAT
APC provides power protection, environmental control and site monitoring services that are designed to proactively identify and correct problems before downtime occurs. Over the years, APC has received more than 150 awards worldwide for reliability and innovation of solutions - more than any other UPS manufacturer. APC's solutions are accepted as "best of breed" across the globe. You deserve the legendary reliability and peace of mind that only APC can provide.
  • Guaranteed UPS compatibility
    Tested and approved to restore the performance of your APC UPS. Maintains UPS safety certifications (UL, VDE, CSA) and lifetime equipment protection policy (as applicable).
  • Long battery life
    Designed for complete compatibility with the intelligent battery management system. Fully assembled for easy hot-swap installation APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #55 - UPS battery - Lead Acid
UPS battery
24.3 kg
Lead Acid 2-cell
Battery Form Factor
Internal
14.2 cm x 18.3 cm x 17.3 cm
1-year warranty
P/N: DLA2200, SMT2200, SMT2200C, SMT2200I, SMT2200I-AR, SMT2200IC, SMT2200TW, SMT2200US, SMT3000, SMT3000C, SMT3000I, SMT3000I-AR, SMT3000IC, SMT3000TW, SUA2200-BR, SUA2200I_IN, SUA2200ICH-45, SUA2200TW, SUA2200UXICH, SUA3000-BR, SUA3000ICH, SUA3000ICH-45, SUA3000I-IN, SUA3000UXI, SUA3000UXICH
UPS battery
Battery Enclosure Type
Internal
2-cell Lead Acid
Spill-proof
Hot-swappable
Limited warranty - replace or repair - 1 year
0 - 95%
14.2 cm
18.3 cm
17.3 cm
24.3 kg
Shipping Width
29.5 cm
Shipping Depth
27.7 cm
Shipping Height
53.8 cm
Shipping Weight
26.7 kg
P/N: DLA2200, DLA2200I, SMT2200, SMT2200C, SMT2200I, SMT2200I-AR, SMT2200IC, SMT2200TW, SMT2200US, SMT3000, SMT3000C, SMT3000I, SMT3000I-AR, SMT3000IC, SMT3000TW, SU48RMXLBP3U, SU5000R5T-TF3, SUA2200, SUA2200-BR, SUA2200I, SUA2200I_IN, SUA2200ICH, SUA2200ICH-45, SUA2200TW, SUA2200UXI, SUA2200UXICH, SUA2200X115, SUA2200XL, SUA2200XLI, SUA2200XL-NETPKG, SUA3000, SUA3000-BR, SUA3000I, SUA3000ICH, SUA3000ICH-45, SUA3000I-IN, SUA3000UXI, SUA3000UXICH, SUA3000XL, SUA3000XLI, SUA3000XL-NETPKG, SUA3000XLT, SUA48XLBP, SUA5000R5TXFMR, SUA5000RMI5U, SUA5000RMT5U
Resources
The following resources are available for the APC Replacement Battery Cartridge RBC55
Brand: APC
