APC provides power protection, environmental control and site monitoring services that are designed to proactively identify and correct problems before downtime occurs. Over the years, APC has received more than 150 awards worldwide for reliability and innovation of solutions - more than any other UPS manufacturer. APC's solutions are accepted as "best of breed" across the globe. You deserve the legendary reliability and peace of mind that only APC can provide.
Long battery life
APC Replacement Battery Cartridge #17 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system. -
Fully assembled for easy hot-swap installation
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
 - APC Replacement Battery Cartridge #17 - UPS battery - Lead Acid
 - UPS battery
 - 2.59 kg
- Battery
 - Lead Acid
- Battery Form Factor
 - Internal
- Batteries Qty
 - 1
 - Black
 - 9.4 cm x 15.1 cm x 6.5 cm
 - 2-year warranty
- Designed For
 - P/N: BC650-RSX761, BE700G-RS, BE700-KR, BE700Y-IND, BE850G2, BE850G2-CP, BE850G2-FR, BE850G2-GR, BE850G2-IT, BE850G2-SP, BE850G2-UK, BE850M2, BE850M2-LM, BN900M, BN900M-CA, BVN900M1, BVN950M2, BX1100LI, BX1100LI-MS, BX800CI-AR, BX800CI-RS, BX800CI-ZA, BX800U-LM, BX850M, BX850M-LM60, BX950U-MS
 - UPS battery
- Battery Enclosure Type
 - Internal
 - Black
- Quantity
 - 1
- Technology
 - Lead Acid
 - Leak-proof
 - RoHS
 - Limited warranty - 2 years
 - 0 °C
 - 40 °C
 - 0 - 95%
 - 9.4 cm
 - 15.1 cm
 - 6.5 cm
 - 2.59 kg
- Shipping Width
 - 17.5 cm
- Shipping Depth
 - 21.3 cm
- Shipping Height
 - 8.9 cm
- Shipping Weight
 - 2.86 kg
- Designed For
 - P/N: 515-970, BC650-RSX761, BE650BB, BE650BB-CN, BE650G, BE650G1, BE650G1-CN, BE650G1-LM, BE650G-CN, BE650G-LM, BE650MC, BE650R, BE650R-CN, BE650Y-IN, BE700-AZ, BE700-CP, BE700-FR, BE700G-AZ, BE700G-CP, BE700G-FR, BE700G-GR, BE700G-IT, BE700-GR, BE700G-RS, BE700G-SP, BE700G-UK, BE700-IT, BE700-KR, BE700-RS, BE700-SP, BE700-UK, BE700Y-IND, BE725BB, BE750G, BE750G-CN, BE750G-LM, BE850G2, BE850G2-CP, BE850G2-FR, BE850G2-GR, BE850G2-IT, BE850G2-SP, BE850G2-UK, BE850M2, BE850M2-LM, BK500MC, BK600C, BK650-AS, BK650EI, BN600, BN700MC, BN900M, BN900M-CA, BP500U, BP650SX107, BP700UC, BR700G, BVN900M1, BVN950M2, BX1100LI, BX1100LI-MS, BX800CI-AR, BX800CI-LM, BX800CI-MS, BX800CI-RS, BX800CI-ZA, BX800U-LM, BX850M, BX850M-LM60, BX950U-MS, DL650T, DL725VT
