APC Replacement Battery Cartridge
Quicklinx: 8N4RWS00 Mfr#: APCRBC133
Type: Battery
Power Rating: [N/A]
£310.43 ex VAT
£372.51 inc VAT
Tested and approved to restore the performance of your APC UPS. It maintains UPS safety certifications (UL, VDE, and CSA) and lifetime equipment protection policy (as applicable). It designed by APC by Schneider Electric exclusively for APC UPS's for complete compatibility with the intelligent battery management system.
  • Guaranteed UPS compatibility
  • Long battery life
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #133 - UPS battery - Lead Acid
UPS battery
12 kg
Lead Acid
Batteries Qty
1
21.6 cm x 34.3 cm x 8.3 cm
SMT1500RM2U, SMT1500RM2UTW, SMT1500RMI2U, SMT1500RMUS
UPS battery
Quantity
1
Lead Acid
RoHS
0 - 95%
21.6 cm
34.3 cm
8.3 cm
12 kg
Shipping Width
36.8 cm
Shipping Depth
49.5 cm
Shipping Height
15.2 cm
Shipping Weight
12.6 kg
Type: Battery
Power Rating: [N/A]
Brand: APC
