Tested and approved to restore the performance of your APC UPS. It maintains UPS safety certifications (UL, VDE, and CSA) and lifetime equipment protection policy (as applicable). It designed by APC by Schneider Electric exclusively for APC UPS's for complete compatibility with the intelligent battery management system.
Guaranteed UPS compatibility
Tested and approved to restore the performance of your APC UPS. It maintains UPS safety certifications (UL, VDE, and CSA) and lifetime equipment protection policy (as applicable). -
Long battery life
It designed by APC by Schneider Electric exclusively for APC UPS's for complete compatibility with the intelligent battery management system. -
Fully assembled for easy hot-swap installation
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
- APC Replacement Battery Cartridge #133 - UPS battery - Lead Acid
- UPS battery
- 12 kg
- Battery
- Lead Acid
- Batteries Qty
- 1
- Black
- 21.6 cm x 34.3 cm x 8.3 cm
- 2-year warranty
- Designed For
- SMT1500RM2U, SMT1500RM2UTW, SMT1500RMI2U, SMT1500RMUS
- UPS battery
- Black
- Quantity
- 1
- Technology
- Lead Acid
- RoHS
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 21.6 cm
- 34.3 cm
- 8.3 cm
- 12 kg
- Shipping Width
- 36.8 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 15.2 cm
- Shipping Weight
- 12.6 kg
- Designed For
