APC Replacement Battery Cartridge #88
Quicklinx: D04NWS00 Mfr#: APCRBC88
Hurry, only 2 left in stock!
£311.71 ex VAT
£374.05 inc VAT
Genuine APC RBC are tested and certified for compatibility to restore UPS performance to the original specifications.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Plug and Play setup
    Fast and Easy set up
APC Replacement Battery Cartridge #88 - UPS battery - Lead Acid
UPS battery
10.45 kg
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
20.7 cm x 48 cm x 3.8 cm
1-year warranty
P/N: SMT1500RM1U, SMT1500RMI1U
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Maintenance free, sealed, leak-proof
RoHS, REACH
Limited warranty - 1 year
0 - 95%
20.7 cm
48 cm
3.8 cm
10.45 kg
Shipping Width
32.7 cm
Shipping Depth
60.3 cm
Shipping Height
18.1 cm
Shipping Weight
11.82 kg
Brand: APC
