Genuine APC RBC are tested and certified for compatibility to restore UPS performance to the original specifications.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Plug and Play setup
Fast and Easy set up
- APC Replacement Battery Cartridge #88 - UPS battery - Lead Acid
- UPS battery
- 10.45 kg
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- 20.7 cm x 48 cm x 3.8 cm
- 2-year warranty
- Designed For
- P/N: SMT1500RM1U, SMT1500RM1UC, SMT1500RMI1U, SMT1500RMX93
- UPS battery
- Battery Enclosure Type
- Internal
- Quantity
- 1
- Technology
- Lead Acid
- Maintenance free, sealed, leak-proof
- RoHS, REACH
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 20.7 cm
- 48 cm
- 3.8 cm
- 10.45 kg
- Shipping Width
- 32.7 cm
- Shipping Depth
- 60.3 cm
- Shipping Height
- 18.1 cm
- Shipping Weight
- 11.82 kg
- Designed For
