APC Replacement Battery Cartridge #46
Quicklinx: D051WS00 Mfr#: RBC46
£42.33 ex VAT
£50.79 inc VAT
APC provides power protection, environmental control and site monitoring services that are designed to proactively identify and correct problems before downtime occurs. Over the years, APC has received more than 150 awards worldwide for reliability and innovation of solutions - more than any other UPS manufacturer. APC's solutions are accepted as "best of breed" across the globe. You deserve the legendary reliability and peace of mind that only APC can provide.
  • Long battery life
    APC Replacement Battery Cartridge #46 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system.
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #46 - UPS battery - Lead Acid
UPS battery
1.7 kg
Lead Acid
Batteries Qty
1
9.9 cm x 7.4 cm x 11.2 cm
1-year warranty
Back-UPS ES 350, 500
UPS battery
Quantity
1
Lead Acid
Spill-proof
Limited warranty - 1 year
0 - 95%
9.9 cm
7.4 cm
11.2 cm
1.7 kg
APC Back-UPS ES 350, 500
Brand: APC
