APC Replacement Battery Cartridge #151
Quicklinx: D04KWS00 Mfr#: APCRBC151
£349.74 ex VAT
£419.68 inc VAT
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
  • Maintenance-free convenience
    The APC Replacement Battery Cartridge #151 features a sealed, maintenance-free lead acid battery, eliminating the need for regular upkeep and ensuring a reliable power source for your PC.
  • Wide operational range
    Designed to perform in a variety of conditions, this UPS battery operates efficiently across a humidity range of 0 - 95% and temperature extremes from 0°C to 45°C, making it a versatile choice for any environment.
  • Eco-friendly design
    Compliant with REACH and RoHS standards, the APC Replacement Battery Cartridge #151 is an environmentally responsible choice, minimizing its ecological footprint while providing safe and dependable power.
APC Replacement Battery Cartridge #151 - UPS battery - Lead Acid
UPS battery
10 kg
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
21.6 cm x 34.3 cm x 8.3 cm
P/N: SMC3000I, SMC3000RMI2U
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Voltage Provided
12 V
Maintenance free, sealed
RoHS, REACH
45 °C
0 - 95%
21.6 cm
34.3 cm
8.3 cm
10 kg
Shipping Width
36.8 cm
Shipping Depth
49.5 cm
Shipping Height
15.2 cm
Shipping Weight
10.91 kg
Brand: APC
