Genuine APC RBC are tested and certified for compatibility to restore UPS performance to the original specifications.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
- APC Replacement Battery Cartridge #143 - UPS battery - Lead Acid - 600 Ah
- UPS battery
- 22.27 kg
- Battery
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Black
- 27.9 cm x 48.1 cm x 22.5 cm
- 2-year warranty
- Designed For
- P/N: SCL500RMI1UC, SMX120BP, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200HV, SMX2200HVNC, SMX3000HV, SMX3000HV-BR, SMX3000HVNC, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LVNC, SMX3000LVNCUS, SMX3000LVUS, SU2200RMXLNET, SUA3000RMXL3U, SUA3000XL-NETPKG
- UPS battery
- Battery Enclosure Type
- Internal
- Black
- Quantity
- 1
- Technology
- Lead Acid
- Voltage Provided
- 120 V
- Capacity
- 600 Ah
- Maintenance free, sealed, leak-proof
- CSA, UL, VDE, RoHS, REACH
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- 27.9 cm
- 48.1 cm
- 22.5 cm
- 22.27 kg
- Shipping Width
- 29.3 cm
- Shipping Depth
- 49.5 cm
- Shipping Height
- 25.3 cm
- Shipping Weight
- 25.18 kg
- Designed For
