APC Replacement Battery Cartridge #143
Quicklinx: CLP5WS00 Mfr#: APCRBC143
£434.48 ex VAT
£521.37 inc VAT
Genuine APC RBC are tested and certified for compatibility to restore UPS performance to the original specifications.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
APC Replacement Battery Cartridge #143 - UPS battery - Lead Acid - 600 Ah
UPS battery
22.27 kg
Lead Acid - 600 Ah
Battery Form Factor
Internal
Batteries Qty
1
27.9 cm x 48.1 cm x 22.5 cm
P/N: SCL500RMI1UC, SMX120BP, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200HV, SMX2200HVNC, SMX3000HV, SMX3000HV-BR, SMX3000HVNC, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LVNC, SMX3000LVNCUS, SMX3000LVUS, SU2200RMXLNET, SUA3000RMXL3U, SUA3000XL-NETPKG
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Voltage Provided
120 V
600 Ah
Maintenance free, sealed, leak-proof
CSA, UL, VDE, RoHS, REACH
0 - 95%
27.9 cm
48.1 cm
22.5 cm
22.27 kg
Shipping Width
29.3 cm
Shipping Depth
49.5 cm
Shipping Height
25.3 cm
Shipping Weight
25.18 kg
Brand: APC
