APC Replacement Battery Cartridge #132
Quicklinx: 92PHWS00 Mfr#: APCRBC132
Type: Battery
Power Rating: [N/A]
£273.34 ex VAT
£328.00 inc VAT
Tested and approved to restore the performance of your APC UPS. It maintains UPS safety certifications (UL, VDE, and CSA) and lifetime equipment protection policy (as applicable). It designed by APC by Schneider Electric exclusively for APC UPS's for complete compatibility with the intelligent battery management system.
  • Guaranteed UPS compatibility
  • Long battery life
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #132 - UPS battery - Lead Acid
UPS battery
10 kg
Lead Acid
Batteries Qty
1
21.6 cm x 34.3 cm x 8.3 cm
P/N: SMC1500-2U, SMC1500-2UC, SMC1500-2UTW, SMC1500I-2U, SMT1000R2I-AR, SMT1000RM2U, SMT1000RM2UC, SMT1000RM2UTW, SMT1000RMI2U
UPS battery
Quantity
1
Lead Acid
RoHS
0 - 95%
21.6 cm
34.3 cm
8.3 cm
10 kg
Shipping Width
36.8 cm
Shipping Depth
49.5 cm
Shipping Height
15.2 cm
Shipping Weight
10.9 kg
Type: Battery
Power Rating: [N/A]
Brand: APC
