APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
Long battery life
APC Replacement Battery Cartridge #105 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system. -
Fully assembled for easy hot-swap installation
APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
- APC Replacement Battery Cartridge #105 - UPS battery - Lead Acid
- UPS battery
- 24.6 kg
- Battery
- Lead Acid
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- 16.5 cm x 57.2 cm x 10.8 cm
- 1-year warranty
- Designed For
- P/N: SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA3000RMXLI3U, SUA48RMXLBP3U, SUM48RMXLBP2U
- UPS battery
- Battery Enclosure Type
- Internal
- Quantity
- 1
- Technology
- Lead Acid
- Hot-swappable
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 0 - 95%
- 16.5 cm
- 57.2 cm
- 10.8 cm
- 24.6 kg
- Shipping Width
- 31.1 cm
- Shipping Depth
- 73.7 cm
- Shipping Height
- 27.9 cm
- Shipping Weight
- 26.4 kg
- Designed For
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
5H54 046975 Condition: Customer return - item has been opened but is in excellent condition |
£59.15 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
