APC Replacement Battery Cart #105
Quicklinx: 5H54WS00 Mfr#: APCRBC105
£403.37 ex VAT
£484.04 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Long battery life
    APC Replacement Battery Cartridge #105 is designed by APC by Schneider Electric exclusively for APC UPSs for complete compatibility with the intelligent battery management system.
  • Fully assembled for easy hot-swap installation
    APC RBCs are safe, reliable and contain a minimum number of connections saving valuable time. Because APC RBCs are hot-swappable, no network downtime is required in order to install them.
APC Replacement Battery Cartridge #105 - UPS battery - Lead Acid
UPS battery
24.6 kg
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
16.5 cm x 57.2 cm x 10.8 cm
1-year warranty
P/N: SUA2200R3XLNETPKG, SUA2200RMXL3U, SUA2200RMXLI3U, SUA3000R3XLNETPKG, SUA3000RMXL3U, SUA3000RMXL3U-BR, SUA3000RMXLI3U, SUA48RMXLBP3U, SUM48RMXLBP2U
UPS battery
Battery Enclosure Type
Internal
Quantity
1
Lead Acid
Hot-swappable
Limited warranty - 1 year
0 - 95%
16.5 cm
57.2 cm
10.8 cm
24.6 kg
Shipping Width
31.1 cm
Shipping Depth
73.7 cm
Shipping Height
27.9 cm
Shipping Weight
26.4 kg
Resources
The following resources are available for the APC Replacement Battery Cart #105
Brand: APC
