APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Easy to install
Innovative design allows for fast, easy installation by almost anybody
- APC - UPS battery - Lead Acid - 7 Ah
- UPS battery
- 2.5 kg
- Battery
- Lead Acid - 7 Ah
- Battery Form Factor
- Internal
- Black
- 10.2 cm x 14 cm x 4.8 cm
- Designed For
- P/N: CP15U48D, CP16U48NA2, CP18C12NA2, CP24U12AZ3-F, CP24U12NA3, CP24U12NA3-F, CP24U12NA3-F2, CP24U12NA3-F3, CP24U12NA3-F4, CP24U12NA3-F5, CP24U12SC3, CP24U12SC3-F, CP24U12UK3, CP27U13AZ3-F, CP27U13NA3-G, CP27U13NA3-S, CP27U13SC3, CP27U13SC3-F, CP40U48NA3, CP40U48SC3
- UPS battery
- Battery Enclosure Type
- Internal
- Black
- Technology
- Lead Acid
- Voltage Provided
- 12 V
- Capacity
- 7 Ah
- Spill-proof
- 10.2 cm
- 14 cm
- 4.8 cm
- 2.5 kg
- Designed For
