APC Replacement Battery 12V-7AH
Quicklinx: D04YWS00 Mfr#: RBC40
£71.53 ex VAT
£85.83 inc VAT
APC sets the standard in its industry for quality, innovation and support. Its comprehensive solutions, which are designed for both home and corporate environments, improve the manageability, availability and performance of sensitive electronic, network, communications and industrial equipment of all sizes. The mission of APC is to improve the manageability, availability, and performance of information and communication systems through rapid development and delivery of innovative solutions to real customer problems.
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Easy to install
    Innovative design allows for fast, easy installation by almost anybody
APC - UPS battery - Lead Acid - 7 Ah
UPS battery
2.5 kg
Lead Acid - 7 Ah
Battery Form Factor
Internal
10.2 cm x 14 cm x 4.8 cm
P/N: CP15U48D, CP16U48NA2, CP18C12NA2, CP24U12AZ3-F, CP24U12NA3, CP24U12NA3-F, CP24U12NA3-F2, CP24U12NA3-F3, CP24U12NA3-F4, CP24U12NA3-F5, CP24U12SC3, CP24U12SC3-F, CP24U12UK3, CP27U13AZ3-F, CP27U13NA3-G, CP27U13NA3-S, CP27U13SC3, CP27U13SC3-F, CP40U48NA3, CP40U48SC3
UPS battery
Battery Enclosure Type
Internal
Lead Acid
Voltage Provided
12 V
7 Ah
Spill-proof
10.2 cm
14 cm
4.8 cm
2.5 kg
Brand: APC
