APC Rack PDU 2G METERED ZEROU
Quicklinx: 7J5GWS00 Mfr#: AP8853
Type: PDU
Power Rating: [N/A]
£558.53 ex VAT
£670.23 inc VAT
APC Metered Rack Power Distribution Units (PDUs) provide active metering to enable energy optimization and circuit protection. User-defined alarm thresholds mitigate risk with real-time local and remote alerts to warn of potential circuit overloads. Metered Rack PDUs provide power utilization data to allow data center managers to make informed decisions on load balancing and right sizing IT environments to lower total cost of ownership. Metered Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and ultra low profile circuit breakers. Users can access and configure Metered Rack PDUs through secure web, SNMP, or telnet interfaces which are complimented by APC centralized management platforms using InfraStruxure central, operations, capacity, and energy efficiency.
  • Remote management capabilities
    Full-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
  • Local current monitoring display
    The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
  • Alarm thresholds
    Define alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems.
  • Load indicator LED
    Indicates overload and warning conditions based on the user-defined alarm thresholds. It alerts users of potential overloaded circuits.
  • Integrates with StruxureWare data center expert
    An IT-ready, scalable access monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
  • Single input power source
    Supply power from one branch whip to multiple pieces of equipment, conveniently powering rack-mount equipment. Saves time and money during installation by using one branch whip and standard connections.
APC Metered Rack PDU ZeroU 2G - power distribution strip
Power distribution strip - rack-mountable
Rack Size
0U
6.9 g
Input Voltage
AC 200/208/230 V
Output Voltage
AC 230 V
Input Connectors
1 x power IEC 60309 32A
Output connectors
36 x power IEC 60320 C13 , 6 x power IEC 60320 C19
Remote Management Protocol
SNMP, Telnet, HTTP
5.6 cm x 4.4 cm x 179 cm
P/N: AR3357X674, SMC1000I-2UC, SMC1000IC, SMC1500I-2UC, SMX1000US, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200RMLVUS, SMX3000HVTUS, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750US, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10RMXLIX806, SRT5KRMXLTUS, SRT5KRMXLW-TW
Height (Rack Units)
0U
Input Voltage
AC 200/208/230 V
Input Voltage Range
AC 220 - 240 V
Input Connectors
Output Voltage
AC 230 V
Max Electric Current
32 A
Circuit Protection
Circuit breaker
SNMP, Telnet, HTTP
Serial cable - external , Power cable 3 m
Rack Mounting Kit
Included
LCD display, thermal monitoring, humidity monitoring, overload protection
VDE, IEC 60950, RoHS, REACH
5 °C
45 °C
5 - 95%
5.6 cm
4.4 cm
179 cm
6.9 g
Shipping Width
46.2 cm
Shipping Depth
10.7 cm
Shipping Height
200 cm
Shipping Weight
8.6 kg
P/N: AP5607, AP6453CH, AR2200, AR2280, AR2400, AR2400FP1, AR2401, AR2407, AR2480, AR2487, AR2487G, AR2500, AR2507, AR2580, AR2587, AR3100G, AR3100TAA, AR3100W, AR3100X609, AR3100X610, AR3100X617, AR3105, AR3105SP, AR3105W, AR3107G, AR3107SP, AR3107X609, AR3107X610, AR3107X617, AR3130, AR3140G, AR3140W, AR3150SP, AR3150W, AR3150X609, AR3150X610, AR3150X617, AR3155, AR3155SP, AR3155W, AR3157SP, AR3157X609, AR3157X610, AR3157X617, AR3180G, AR3300G, AR3300SP, AR3300W, AR3300X609, AR3300X610, AR3300X617, AR3305, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3307X609, AR3307X610, AR3307X617, AR3340, AR3340G, AR3340W, AR3347, AR3350SP, AR3350W, AR3350X609, AR3350X610, AR3350X617, AR3355, AR3355SP, AR3355W, AR3357SP, AR3357X609, AR3357X610, AR3357X617, AR3357X674, NBES0302, NBPD0160A, NBPD0171, NBPD0172, NBPD0180, NBWL0355A, NBWL0356A, SMC1000, SMC1000-2U, SMC1000-BR, SMC1000I, SMC1000I-2U, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC1500, SMC15002U-BR, SMC1500-BR, SMC1500I, SMC1500I-2U, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I-2U, SMC3000RMI2U, SMT1500RM1U, SMT1500RM2U, SMT1500RMI1U, SMT2200RM2UC, SMT3000I2U-BR, SMT3000RM2UC, SMT3000RMT2U, SMX1000US, SMX1500RMNCUS, SMX1500RMUS, SMX2000LV, SMX2000LVNC, SMX2000LVNCUS, SMX2000LVUS, SMX2200HV, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMHV2U, SMX2200RMLV2U, SMX2200RMLVUS, SMX3000HV, SMX3000HV-BR, SMX3000HVNC, SMX3000HVT, SMX3000HVTUS, SMX3000LV, SMX3000LV2U-BR, SMX3000LVNC, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMHV2U, SMX3000RMHV2UNC, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750-NMC, SMX750US, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLI, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT5KRMXLT, SRT5KRMXLT-IEC, SRT5KRMXLTUS, SRT5KRMXLW-HW, SRT5KRMXLW-TW, SRT6KRMXLI, SRT6KRMXLT, SRT6KRMXLT-IEC, SRT8KRMXLI, SRT8KRMXLT, SRT8KRMXLT-IEC, SUA3000RMXL3U-BR, SURT3000XLI-ET, SURT5000XLIX438, SYA12K16RMICH, SYA16K16RMICH, SYA8K16RMICH, SYAF16KRMICH
7J5G APC Temperature and Humidity Sensor In Stock £123.67
7J5G APC AP9520TH TEMP & HUMIDITY In Stock £216.78
7J5G APC APC POWERCORD C19 TO C20 1.8M In Stock £149.61
7J5G APC Power Cord Locking C19 to C20 3.0m In Stock £55.95
7J5G APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m In Stock £47.00
7J5G APC Power Cable (pack of 6) 1.22m In Stock £71.60
7J5G APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m In Stock £105.16
Type: PDU
Power Rating: [N/A]
Brand: APC
Price Range Ex VAT: £500 - £750
Stock Status: In stock
