APC Metered Rack Power Distribution Units (PDUs) provide active metering to enable energy optimization and circuit protection.
User-defined alarm thresholds mitigate risk with real-time local and remote alerts to warn of potential circuit overloads. Metered Rack PDUs provide power utilization data to allow data center managers to make informed decisions on load balancing and right sizing IT environments to lower total cost of ownership.
Metered Rack PDUs include real power monitoring, a temperature/humidity sensor port, locking IEC receptacles, and ultra low profile circuit breakers.
Users can access and configure Metered Rack PDUs through secure web, SNMP, or telnet interfaces which are complimented by APC centralized management platforms using InfraStruxure central, operations, capacity, and energy efficiency.
                Remote management capabilitiesFull-featured network management interfaces that provide standards-based management via Web, SNMP, and Telnet. Allows users to access, configure, and manage units from remote locations to save valuable time. Associated with this feature is the ability to quickly and easily upgrade the firmware via network download to installed units for future product enhancements.
                Local current monitoring displayThe aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip.
                Alarm thresholdsDefine alarm thresholds in order to avoid overloaded circuits. Network and visual alarms inform the user of possible problems.
                Load indicator LEDIndicates overload and warning conditions based on the user-defined alarm thresholds. It alerts users of potential overloaded circuits.
                Integrates with StruxureWare data center expertAn IT-ready, scalable access monitoring system that collects, organizes, and distributes critical alerts, surveillance video and key information, providing a unified view of complex physical infrastructure environments from anywhere on the network.
                Flash upgradeableQuickly and easily upgrade firmware via network download for future product enhancements. It eliminates the need to replace products already installed in the field when new features are released.
                Single input power sourceSupply power from one branch whip to multiple pieces of equipment, conveniently powering rack-mount equipment. Saves time and money during installation by using one branch whip and standard connections.
- APC Metered Rack PDU - power distribution strip
- Power distribution strip - rack-mountable
- 2.9 kg
- Input Voltage
- AC 200/208/230 V
- Output Voltage
- AC 200/208/230 V
- Input Connectors
- Power IEC 60320 C20
- Output connectors
- 18 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Networking
- RS-232
- Remote Management Protocol
- SNMP, Telnet, HTTP
- Black
- 5.6 cm x 4.4 cm x 90.2 cm
- 2-year warranty
- Designed For
- P/N: AR3103SP, AR3106SP, AR9300SP, AR9307SP, AR9307SP-R, SCL500RMI1UC, SMT2200I-AR, SMT2200R2I-AR, SMT3000I-AR, SMT3000R2I-AR, SMX1000C, SMX1500RM2UC, SMX1500RM2UCNC, SMX1500RMNCUS, SMX750C, SMX750CNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10RMXLIX806, SRT1500XLI, SRT2200XLI-KR, SRT5KRMXLW-TW
- Black
- Input Voltage
- AC 200/208/230 V
- Input Voltage Range
- AC 100 - 240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 200/208/230 V
- Max Electric Current
- 20 A
- Remote Management Interface
- RS-232
- 1 x management (RS-232)
- Cables Included
- Serial cable
- LED indicators, firmware upgradable
- VDE, IEC 60950, CSA 22.2 No. 60950, RoHS, UL 60950-1, REACH
- Limited warranty - 2 years
- 5 °C
- 45 °C
- 5 - 95%
- 5.6 cm
- 4.4 cm
- 90.2 cm
- 2.9 kg
- Shipping Width
- 16.2 cm
- Shipping Depth
- 10.7 cm
- Shipping Height
- 112 cm
- Shipping Weight
- 4.2 kg
- Designed For
- P/N: ACDC2513, AP6221CH, AR2200, AR2280, AR2487G, AR3100G, AR3100TAA, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3107G, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3180G, AR3300G, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3307W, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR3357X674, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, AR9300SP, AR9300SP-R, AR9307SP, AR9307SP-R, DLT3000RMI2U, NBES0302, NBPD0160A, NBPD0180, NBWL0355A, NBWL0356A, SCL500RMI1UC, SMC1000-BR, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC15002U-BR, SMC1500-BR, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I, SMC2000I-2U, SMC3000I, SMC3000RMI2U, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RMI2UC, SMT2200RMI2UNC, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-6W, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RMI2UC, SMT3000RMI2UNC, SMX1000C, SMX1000US, SMX1500RM2UC, SMX1500RM2UCNC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMHV2U, SMX2200RMLVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750C, SMX750CNC, SMX750US, SPD10KCBL, SPD20KCBL, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLI, SRT10KRMXLT-IEC, SRT10KXLI, SRT10KXLT-IEC, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT1500XLI, SRT2200RMXLI, SRT2200RMXLI-NC, SRT2200XLI, SRT2200XLI-KR, SRT3000RMXLI, SRT3000RMXLI-NC, SRT3000RMXLW-IEC, SRT3000XLI, SRT3000XLW-IEC, SRT5KRMXLI, SRT5KRMXLI-6W, SRT5KRMXLIM, SRT5KRMXLT, SRT5KRMXLT-IEC, SRT5KRMXLTUS, SRT5KRMXLW-HW, SRT5KRMXLW-TW, SRT5KXLI, SRT6KRMXLI, SRT6KRMXLI-6W, SRT6KRMXLIM, SRT6KRMXLT, SRT6KRMXLT-IEC, SRT6KXLI, SRT6KXLT-IEC, SRT8KRMXLI, SRT8KRMXLT, SRT8KRMXLT-IEC, SRT8KXLI, SRT8KXLT-IEC, SUA2200ICH-45, SUA3000ICH-45, SUA3000I-IN, SURT3000XLI-ET, SURT5000XLIX438, SURTD5000XLI-ET, SYAF16KRMICH
|  | APC Temperature and Humidity Sensor | In Stock | £132.71 |
|  | APC AP9520TH TEMP & HUMIDITY | In Stock | £258.75 |
|  | APC Power Cord Locking C19 to C20 3.0m | In Stock | £69.19 |
|  | APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £66.24 |
|  | APC Power Cord Kit (6 ea) Locking C13 to C14 0.6m | In Stock | £58.29 |
|  | APC Power Cable (pack of 6) 1.22m | In Stock | £87.14 |
|  | APC Power Cord Kit (6 ea) - Locking - C13 to C14 - 1.8m | In Stock | £131.51 |
|  | APC Power Cord Kit (6 ea) Locking C13 to C14 (90 Degree) 1.2m | In Stock | £101.37 |
