APC's Metered Rack Power Distribution Units (PDUs) provide power distribution as well as equips on-site installers with the ability to monitor the aggregate current draw as equipment is connected to the unit. These Metered Rack PDUs also have alarm thresholds that when exceeded alert users of potential problems. These features help eliminate the possibility of an overloaded circuit.
- APC Metered Rack PDU - power distribution strip
- Power distribution strip - rack-mountable
- Cord Length
- 3.05 m
- Rack Size
- 0U
- 3.1 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 16 x power IEC 60320 C13
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS
- Black
- 5.6 cm x 4.5 cm x 124.5 cm
- 2-year warranty
- Designed For
- P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200RMI3U.1, SU2200RMXLI3U-3EW, SU3000RMXLI3U-3EW, SU5000RMXLI5U-3EW, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA750IX38, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
- Height (Rack Units)
- 0U
- Cord Length
- 3.05 m
- Black
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 200 - 250 V
- Input Voltage Margin
- ± 10%
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Max Electric Current
- 10 A
- 1 x LAN - RJ-45 , 1 x management - RJ-11
- Cables Included
- Power cable - integrated - 3.05 m
- Rack Mounting Kit
- Included
- CISPR 22 Class A, EN 60950, IEC 61000-3-2, IEC 61000-3-3, VDE, IEC 60950, EN55024, EN55022 Class A
- Limited warranty - 2 years
- -5 °C
- 45 °C
- 5 - 95%
- 5.6 cm
- 4.5 cm
- 124.5 cm
- 3.1 kg
- Designed For
- P/N: AR3100, AR3150, SMX3000RMHV2UNC, SU1400RMXLI3U, SU1400RMXLI3U U, SU1400RMXLI3U-1EW, SU1400RMXLI3U-2EW, SU1400RMXLI3U-3EW, SU1400RMXLIB3U, SU2200R3IBX120, SU2200RMI3U.1, SU2200RMXLI3U, SU2200RMXLI3U-1EW, SU2200RMXLI3U-2EW, SU2200RMXLI3U-3EW, SU3000R3IBX120, SU3000R3IX160, SU3000RMINET, SU3000RMINET-1EW, SU3000RMINET-2EW, SU3000RMINET-3EW, SU3000RMTX136, SU3000RMXLI3U, SU3000RMXLI3U-1EW, SU3000RMXLI3U-2EW, SU3000RMXLI3U-3EW, SU5000R51BX120, SU5000R5IBX120, SU5000R5TBX135, SU5000RMI5U, SU5000RMI5U-1EW, SU5000RMI5U-2EW, SU5000RMI5U-3EW, SU5000RMXLI5U, SU5000RMXLI5U-1EW, SU5000RMXLI5U-2EW, SU5000RMXLI5U-3EW, SU700RMI2U-1EW, SU700RMI2U-2EW, SU700RMI2U-3EW, SUA1000RMI2U, SUA1000RMI2U-3EW, SUA1000RMI2U-GLD, SUA1500RMI2U, SUA1500RMI2U-2EW, SUA1500RMI2U-SLV, SUA2200RMI2U-1EW, SUA2200RMI2U-SLV, SUA2200RMXLI3U, SUA3000I, SUA3000R2IX322, SUA3000RMI, SUA3000RMI2U, SUA3000RMI2U-1EW, SUA3000RMI2U-2EW, SUA3000RMI2U-3EW, SUA3000RMI2U-BRZ, SUA3000RMI2U-GLD, SUA3000RMI2U-SLV, SUA750IX38, SUA750RMI1U, SUA750RMI2U, SUA750RMI2U-3EW, SUA750RMI2U-BRZ, SUA750RMI2U-GLD, SUA750RMI2U-SLV, SURT3000XLI, SURT3000XLI/S, SURT3000XLI-BRZ, SURT3000XLI-GLD, SURT3000XLI-SLV, SURT3000XLI-TU
