APC Rack PDU, Basic, Zero U, 10A,2
Quicklinx: 4KMCWS00 Mfr#: AP9568
Type: PDU
Power Rating: 2.3kW
£279.09 ex VAT
£334.90 inc VAT
APC offers a wide variety of Basic Rack Power Distribution Units (PDUs), which allow users to distribute power outlets to rack-mount equipment. Horizontal and vertical units are available as well as a variety of power inputs and outputs to fit most power environments. Basic Rack PDUs are InfraStruXure Certified and mount vertically, without tools in the rear channel of a NetShelter VX.
  • Toolless Rack Mounting Capabilities
    Server cases do not require additional tools to mount into NetShelter Enclosures, which allows the users to quickly and easily mount units in the rear of the enclosure.
  • Vertical Mounting Capabilities
    Easily mounts vertically in racks or enclosures and occupies zero U of valuable rack space, which allows more equipment in the rack. Units that mount vertically are optimized to fit in a NetShelter enclosures.
APC Basic Rack-Mount PDU - power distribution strip - 2.3 kW
Power distribution strip - rack-mountable
Cord Length
1.98 m
2 kg
Input Voltage
AC 208/230 V
Output Voltage
AC 208/230 V
Power Capacity
2.3 kW
Input Connectors
1 x power IEC 60320 C14
Output connectors
15 x power IEC 60320 C13
4.5 cm x 4.5 cm x 61 cm
P/N: AR3103SP, AR3106SP, SCL500RMI1U, SCL500RMI1UC, SCL500RMI1UNC, SMT1500R2I-AR, SMT2200I-AR, SMT2200R2I-AR, SMT3000I-AR, SMT3000R2I-AR, SMTL750RMI2UC, SMX1000C, SMX1500RM2UC, SMX1500RM2UCNC, SMX750C, SMX750CNC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT1500RMXLI, SRT1500XLI, SRT2200XLI-KR, SRT5KRMXLW-TW
Cord Length
1.98 m
Input Voltage
AC 208/230 V
Input Voltage Range
AC 200 - 240 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Output Voltage
AC 208/230 V 50/60 Hz
Max Electric Current
10 A
Power Capacity
2.3 kW
Power cable - external - 1.98 m
Rack Mounting Kit
Included
UL, cUL, VDE
Limited warranty - parts and labour - 2 years , Limited warranty - replacement - 2 years
45 °C
Min Storage Temperature
-25 °C
Max Storage Temperature
65 °C
5 - 95%
Humidity Range Storage
5 - 95%
4.5 cm
4.5 cm
61 cm
2 kg
P/N: AR2487G, AR3100W, AR3103SP, AR3105SP, AR3105W, AR3106SP, AR3107SP, AR3140G, AR3140W, AR3150SP, AR3150W, AR3155SP, AR3155W, AR3157SP, AR3300SP, AR3300W, AR3305SP, AR3305W, AR3307SP, AR3340G, AR3340W, AR3350SP, AR3350W, AR3355SP, AR3355W, AR3357SP, AR3357X674, AR4018IX429, AR4018SP, AR4018SPX429, AR4018SPX431, AR4018SPX432, AR4018X429, AR4024IX431, AR4024SP, AR4024SPX429, AR4024SPX431, AR4024SPX432, AR4038IX432, NBPD0160A, NBWL0355A, NBWL0356A, SCL500RMI1U, SCL500RMI1UC, SCL500RMI1UNC, SMC1000-BR, SMC1000I-2UC, SMC1000I-BR, SMC1000IC, SMC15002U-BR, SMC1500-BR, SMC1500I2U-BR, SMC1500I-2UC, SMC1500I-BR, SMC1500IC, SMC2000I, SMC3000I, SMT1000I-6W, SMT1000I-AR, SMT1000IC, SMT1000R2I-AR, SMT1000RMI2UC, SMT1500I-AR, SMT1500IC, SMT1500R2I-6W, SMT1500R2I-AR, SMT1500RMI2UC, SMT1500RMI2UNC, SMT2200I-AR, SMT2200IC, SMT2200R2I-AR, SMT2200RM2UC, SMT2200RMI2UC, SMT2200RMI2UNC, SMT3000I2U-BR, SMT3000I-AR, SMT3000IC, SMT3000R2I-6W, SMT3000R2I-AR, SMT3000RM2UC, SMT3000RMI2UC, SMT3000RMI2UNC, SMT750RMI2UC, SMT750RMI2UNC, SMTL750RMI2UC, SMX1000C, SMX1000US, SMX1500RM2UC, SMX1500RM2UCNC, SMX1500RMNCUS, SMX1500RMUS, SMX2000LVNCUS, SMX2000LVUS, SMX2200HVNC, SMX2200R2HVNC, SMX2200RMLVUS, SMX3000HV-BR, SMX3000HVTUS, SMX3000LV2U-BR, SMX3000LVNCUS, SMX3000LVUS, SMX3000RMLVUS, SMX3KRMLVNCUS, SMX750C, SMX750CNC, SMX750INC, SMX750US, SPD10KCBL, SPD20KCBL, SRC2000XLI-CC, SRC3KUXI, SRT1000RMXLA, SRT1000RMXLA-NC, SRT1000RMXLI, SRT1000RMXLI-NC, SRT10KRMXLT-IEC, SRT10KXLT-IEC, SRT10RMXLIX806, SRT1500RMXLA, SRT1500RMXLA-NC, SRT1500RMXLI, SRT1500XLI, SRT2200RMXLI, SRT2200RMXLI-NC, SRT2200XLI, SRT2200XLI-KR, SRT3000RMXLI, SRT3000RMXLI-NC, SRT3000RMXLW-IEC, SRT3000XLI, SRT3000XLW-IEC, SRT5KRMXLI-6W, SRT5KRMXLIM, SRT5KRMXLT-IEC, SRT5KRMXLTUS, SRT5KRMXLW-TW, SRT6KRMXLI-6W, SRT6KRMXLIM, SRT6KRMXLT-IEC, SRT6KXLT-IEC, SRT8KRMXLT-IEC, SRT8KXLT-IEC, SUA1000ICH-45, SUA1500I-IN, SUA2200ICH-45, SUA3000I-IN, SURT1000RMXLI-NC, SURT1000XLI-NC, SYAF16KRMICH
4KMC APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.79
Resources
The following resources are available for the APC Rack PDU, Basic, Zero U, 10A,2
Type: PDU
Power Rating: 2.3kW
Brand: APC
