APC rack Automatic Transfer Switches (rack ATS) provide reliable, redundant power to single-corded equipment. The rack ATS has dual input power cords supplying power to the connected load. If the primary power source becomes unavailable, the rack ATS will seamlessly source power from the secondary source without interrupting critical loads. Networked units have built-in network connectivity, which allows for remote management via web, SNMP, or Telnet interfaces.
Local Current Monitoring Display
The aggregate current draw per rack PDU is displayed on the unit via a digital display. The local digital display helps installers avoid overloaded circuits by providing a visible warning when the current draw is close to the maximum amperage draw of the strip. (Available on designated SKUs only)
- APC Automatic Transfer Switch - redundant switch
- Redundant switch - rack-mountable
- Rack Size
- 2U
- 6.9 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Input Connectors
- 2 x power IEC 60309 32A
- Output connectors
- 16 x power IEC 60320 C13 , 2 x power IEC 60320 C19
- Networking
- Ethernet, RS-232
- Remote Management Protocol
- SNMP, Telnet, HTTP
- 43.2 cm x 23.6 cm x 88 cm
- 2-year warranty
- Height (Rack Units)
- 2U
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V
- Max Electric Current
- 32 A
- Remote Management Interface
- Ethernet, RS-232
- 1 x management (RS-232) - RJ-11 , 1 x management (Ethernet) - RJ-45
- Cables Included
- 2 x power cable 2.44 m , Serial cable - external
- Rack Mounting Kit
- Included
- Current meter, overload protection
- EN55022 Class A, RoHS Exemption 7b, FCC Part 15 A
- Limited warranty - 2 years
- -5 °C
- 45 °C
- 5 - 95%
- 43.2 cm
- 23.6 cm
- 88 cm
- 6.9 kg
- Shipping Width
- 61.3 cm
- Shipping Depth
- 35.6 cm
- Shipping Height
- 18.4 cm
- Shipping Weight
- 9.4 kg
