APC provides power protection, environmental control and site monitoring services that are designed to proactively identify and correct problems before downtime occurs. Over the years, APC has received more than 150 awards worldwide for reliability and innovation of solutions - more than any other UPS manufacturer. APC's solutions are accepted as "best-of-breed" across the globe. You deserve the legendary reliability and peace of mind that only APC can provide.
Catastrophic Event Protection
SurgeArrest components such as MOVs and Thermal fuse ensure instantaneous reaction to lightning strikes and wiring faults. If the surge components are damaged due to power spike or over voltage, excess power cannot reach your equipment. Unlike the APC SurgeArrest products, most surge suppressors continue to let power through even after circuits have been damaged, leaving your equipment exposed to other damaging surges.
 - APC ProtectNet - surge protector
 - Surge protector - external
 - 60 g
- Input Connectors
 - 1 x 9 pin D-Sub (DB-9)
- Output connectors
 - Beige
 - 3.6 cm x 1.5 cm x 7.6 cm
 - Beige
- Input Connectors
- Power Output Connectors Details
- Surge Suppression
- Surge Response Time
 - 1 ns
- Clamping Level
 - 40 V
- Circuit Protection
 - Circuit breaker
 - 1 x RS-232 - 9 pin D-Sub (DB-9)
- Connections
 - 1 x serial - RS-232 - 9 pin D-Sub (DB-9)
 - 15 °C
 - 45 °C
 - 0 - 95%
 - 3.6 cm
 - 1.5 cm
 - 7.6 cm
 - 60 g
