APC Power Saving Back-UPS Pro 900
Quicklinx: 7C0FWS00 Mfr#: BR900GI
Type: UPS
Power Rating: 540Watt
44 in stock
£189.71 ex VAT
£227.65 inc VAT
The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. And it features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, like power-saving outlets that automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
Includes: CD with software, Qty 2 - Detachable 1.8 m IEC power cords, USB cable, User Manual, Warranty card
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • Transformer-block spaced outlets
    Protect equipment with input transformer blocks without blocking access to other receptacles
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications
  • Power-saving outlets
    Automatically cuts power to idle equipment to conserve electricity
APC Back-UPS Pro 900 - UPS - 540 Watt - 900 VA
UPS - external
11.7 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
540 Watt / 900 VA
Input Connectors
1 x power IEC 60320
Output connectors
4 x power IEC 60320 (UPS and surge) , 4 x power IEC 60320 (surge)
Lead Acid
Battery Form Factor
Internal
10 cm x 38.2 cm x 25 cm
UPS - external
Battery Enclosure Type
Internal
UPS Technology
Line interactive
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power IEC 60320
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
540 Watt / 900 VA
Dataline Surge Protection
Phone line - RJ-11 , Ethernet 10/100Base-TX - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Lead Acid
Power cable - external - 1.8 m
Audible alarm, LCD display
C-Tick, GOST, GS, NEMKO, A-Tick
Software Included
APC PowerChute Personal Edition
10 cm
38.2 cm
25 cm
11.7 kg
Shipping Width
22.5 cm
Shipping Depth
48.9 cm
Shipping Height
33.3 cm
Shipping Weight
12.8 kg
Type: UPS
Brand: APC
Price Range Ex VAT: 150 - 300
