- Power-saving outlets
- Disconnected battery notification
- Boost and trim Automatic Voltage Regulation (AVR)
- LCD graphics display
Includes: CD with software, Cord management straps, Documentation CD, USB cable, Warranty card
User-replaceable batteries
Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR) -
Audible alarms
Provides notification of changing utility power and UPS power conditions -
Automatic self-test
Periodic battery self-test ensures early detection of a battery that needs to be replaced -
Cold-start capable
Provides temporary battery power when the utility power is out -
Green mode
Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection -
Battery failure notification
Provides early-warning fault analysis on batteries enabling timely preventive maintenance -
Battery replacement without tools
Enables fast battery replacement, lowering Mean Time to Repair (MTTR) -
Safety-agency approved
Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment -
Text and mimic diagrams that display modes of operation, system parameters and alarms -
Hot-swappable batteries
Ensures clean, uninterrupted power to protected equipment while batteries are being replaced -
Battery-protected and surge-only outlets
Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment -
Boost and Trim Automatic Voltage Regulation (AVR)
Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models) -
Dataline surge protection
Provides protection of connected equipment from power surges on the data lines -
Warns when a battery is not available to provide backup power -
USB connectivity
Provides management of the UPS via a USB port (not available on all models) -
Automatically cuts power to idle equipment to conserve electricity -
Automatically steps up low voltage and steps down high voltage to levels that are suitable for your equipment
- APC Back-UPS RS LCD 550 Master Control - UPS - 330 Watt - 550 VA
- UPS - external
- 6.5 kg
- Input Voltage
- AC 230 V
- Output Voltage
- AC 230 V
- Power Capacity
- 330 Watt / 550 VA
- Input Connectors
- 1 x power IEC 60320 C14
- Output connectors
- 3 x power IEC 60320 C13 (surge) , 3 x power IEC 60320 C13 (UPS and surge)
- Battery Form Factor
- Internal
- Batteries Qty
- 1
- Networking
- USB
- Black
- 9.1 cm x 31 cm x 19.2 cm
- 2-year warranty
- UPS - external
- Battery Enclosure Type
- Internal
- Black
- UPS Technology
- Line interactive
- Input Voltage
- AC 230 V
- Input Voltage Range
- AC 176 - 282 V
- Frequency Provided
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Output Voltage
- AC 230 V 50/60 Hz
- Power Capacity
- 330 Watt / 550 VA
- Dataline Surge Protection
- Network - RJ-45
- Output Waveform
- Stepped approximation to a sinewave
- Surge Suppression
- Surge Energy Rating
- 355 Joules
- Circuit Protection
- Circuit breaker
- Quantity
- 1
- Recharge Time
- 12 hours
- Remote Management Interface
- USB
- Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
- TUV GS, C-Tick, GOST, RoHS, A-Tick
- Software Included
- Drivers & Utilities
- Limited warranty - 2 years
- 0 °C
- 40 °C
- 0 - 95%
- Sound Emission
- 40 dBA
- 9.1 cm
- 31 cm
- 19.2 cm
- 6.5 kg
- Shipping Width
- 13.8 cm
- Shipping Depth
- 44.2 cm
- Shipping Height
- 25.2 cm
- Shipping Weight
- 7.7 kg
