APC Power Saving Back-UPS Pro 1500
Quicklinx: 7C0HWS00 Mfr#: BR1500GI
Hurry, only 1 left in stock!
£378.19 ex VAT
£453.82 inc VAT
The Back-UPS Pro provides abundant battery backup power, so you can work through medium and extended length power outages. It safeguards your equipment against damaging surges and spikes that travel along utility and data lines. The Back-UPS Pro also features automatic voltage regulation (AVR), which instantly adjusts high and low voltages to safe levels, so you can work indefinitely during brownouts and overvoltages.
The Back-UPS Pro also includes unique "green" features, automatically turn off idle peripherals. A high efficiency charging system and "AVR Bypass" also reduce power consumption. With the rest of the Back-UPS Pro's standard features, this is the perfect unit to protect your productivity from the constant threat of bad power and lost data.
Includes: CD with software, Qty 2 - Detachable 2.0 m IEC power cords, Telephone Cable, USB cable, User Manual, Warranty card
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Intelligent battery management
    Maximizes battery performance, life, and reliability through intelligent, precision charging
  • Extendable Run Time
    Additional batteries can be added to provide power to the load for an extended period of time in the event of utility supply failure
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Green mode
    Patent-pending operating mode that bypasses unused electrical components in good power conditions to achieve very high operating efficiency without sacrificing any protection
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • LCD graphics display
    Text and mimic diagrams that display modes of operation, system parameters and alarms
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Boost and Trim Automatic Voltage Regulation (AVR)
    Gives higher application availability by correcting low and high voltage conditions without using the battery (not available on all models)
  • Building Wiring Fault Indicator
    This LED informs users of potentially dangerous wiring problems in the wall circuit
  • Resettable circuit breaker
    Easy recovery from overloads; no need to replace a fuse. (Not available on Wall Tap SKUs)
  • Serial connectivity
    Provides management of the UPS via a serial port
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines
  • Disconnected battery notification
    Warns when a battery is not available to provide backup power
  • Transformer-block spaced outlets
    Protect equipment with input transformer blocks without blocking access to other receptacles
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Adjustable voltage-transfer points
    Maximizes useful battery life by widening the input voltage window or tightening the output voltage regulation
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications
  • Power-saving outlets
    Automatically cuts power to idle equipment to conserve electricity
  • Telephone dataline surge protection
    Provides protection of connected equipment from power surges traveling on telephone lines
APC Back-UPS Pro 1500 - UPS - 865 watt - 1500 VA
UPS - external
13.4 kg
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
865 watt / 1500 VA
Input Connectors
Power IEC 60320 C14
Output connectors
5 x power IEC 60320 C13 (surge) , 5 x power IEC 60320 C13 (UPS and surge)
Lead Acid
Batteries Qty
1
RS-232, USB
11.2 cm x 38.1 cm x 30.2 cm
2-year warranty (European Union - 3 years)
UPS - external
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
Power IEC 60320 C14
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
865 watt / 1500 VA
Dataline Surge Protection
Network - RJ-45 , Phone line - RJ-11
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Quantity
1
Lead Acid
Remote Management Interface
RS-232, USB
1 x management (RS-232/USB)
Power cable - external - 1.8 m
Audible alarm, LCD display, Automatic Voltage Regulation (AVR)
GOST, GS, NEMKO, RoHS
Software Included
Drivers & Utilities, APC PowerChute Personal Edition
Limited warranty - 2 years , European Union: limited warranty - 3 years
11.2 cm
38.1 cm
30.2 cm
13.4 kg
Shipping Width
23.8 cm
Shipping Depth
48.9 cm
Shipping Height
38.2 cm
Shipping Weight
14.5 kg
7C0H APC Service Pack 1 Year Warranty Extension In Stock £49.20
7C0H APC Service Pack 3 Year Warranty Extension In Stock £108.71
