APC Power-Saving Back-UPS ES 8 Outlet 700VA 230V
Quicklinx: 6P5MWS00 Mfr#: BE700G-UK
Type: UPS
Power Rating: 405Watt
£103.94 ex VAT
£124.72 inc VAT
The Back-UPS ES offers affordable battery backup and surge protection for home computers. With enough power outlets to protect your entire system, built-in phone/fax/modem line (DSL compatible) protection and easy-to-install safe system shutdown software all make this power protection solution the best value for home and home office computers.
  • User-replaceable batteries
    Increases availability by allowing a trained user to perform upgrades and replacements of the batteries reducing Mean Time to Repair (MTTR)
  • Audible alarms
    Provides notification of changing utility power and UPS power conditions
  • Automatic self-test
    Periodic battery self-test ensures early detection of a battery that needs to be replaced
  • Cold-start capable
    Provides temporary battery power when the utility power is out
  • Battery failure notification
    Provides early-warning fault analysis on batteries enabling timely preventive maintenance
  • Battery replacement without tools
    Enables fast battery replacement, lowering Mean Time to Repair (MTTR)
  • Safety-agency approved
    Ensures the product has been tested and approved to work safely with the connected service provider equipment and within the specified environment
  • Hot-swappable batteries
    Ensures clean, uninterrupted power to protected equipment while batteries are being replaced
  • Battery-protected and surge-only outlets
    Reserves power capacity and run time for connected equipment that require UPS battery back-up while providing surge only protection for less critical equipment
  • Dataline surge protection
    Provides protection of connected equipment from power surges on the data lines
  • USB connectivity
    Provides management of the UPS via a USB port (not available on all models)
  • Adjustable voltage sensitivity
    Provides the ability to adapt the UPS for optimal performance in specific power environments or generator applications
APC Back-UPS ES 700 - UPS - 405 Watt - 700 VA
UPS - external
6.9 kg
United Kingdom
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
405 Watt / 700 VA
Input Connectors
1 x power BS 1363
Output connectors
4 x power BS 1363 (surge) , 4 x power BS 1363 (UPS and surge)
Lead Acid
Battery Form Factor
Internal
Batteries Qty
1
Run Time (Up To)
3.5 min at full load
22.4 cm x 31.1 cm x 8.9 cm
3-year warranty
UPS - external
Battery Enclosure Type
Internal
United Kingdom
UPS Technology
Off-line
Input Voltage
AC 230 V
Frequency Provided
47 - 63 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power BS 1363
Output Voltage
AC 230 V 47 - 63 Hz
Power Capacity
405 Watt / 700 VA
Dataline Surge Protection
Network/phone line - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Run Time (Up To)
Recharge Time
16 hours
Power cable - integrated - 1.8 m , Phone cable - external
Audible alarm, LED indicators
UL 1449, RoHS
Limited warranty - 3 years
0 - 95%
22.4 cm
31.1 cm
8.9 cm
6.9 kg
Shipping Width
27.9 cm
Shipping Depth
40 cm
Shipping Height
12.7 cm
Shipping Weight
7.8 kg
Type: UPS
Brand: APC
Price Range Ex VAT: 100 - 150
