Protecting just the AC line for a notebook computer is not enough. Lightning or other damaging surges can enter and destroy your equipment through the phone line as well. The SurgeArrest Notebook Protector protects both paths - and guarantees it!
                Lightning and Surge ProtectionTo prevent damage to your equipment from electric power surges and spikes
                Protection Working IndicatorSurgeArrest will warn you if its circuitry has been damaged by heavy strike or power line surge and it is unable to provide 100% protection. If still under warranty, APC will then replace your damaged SurgeArrest free of charge
- APC SurgeArrest Notebook Pro - surge protector
- Surge protector - external
- 0.1 kg
- Localisation
- Middle East, Africa, Europe
- Input Voltage
- AC 230 V
- Input Connectors
- 1 x power IEC 60320 C6
- Output connectors
- 1 x power IEC 60320 C5
- Silver
- 3.2 cm x 11 cm x 2.8 cm
- Limited lifetime warranty
- Silver
- Localisation
- Input Voltage
- AC 230 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- Power Output Connectors Details
- Max Electric Current
- 4 A
- Dataline Surge Protection
- Network/phone line - RJ-45/RJ-11 - 1 input line / 2 output lines
- Surge Suppression
- Surge Response Time
- 1 ns
- Surge Energy Rating
- 600 Joules
- Clamping Level
- 330 V
- Cables Included
- Phone cable - external - 1.8 m , Network cable 30 cm
- CSA, UL, GS, NOM, VDE, FCC Part 68
- Limited warranty - lifetime
- 0 °C
- 40 °C
- 0 - 95%
- 3.2 cm
- 11 cm
- 2.8 cm
- 0.1 kg
