APC Netshelter SX Roof Fan Tray 208-230 VAC
Quicklinx: 8988WS00 Mfr#: ACF502
Product Type: Rack fan tray
£310.07 ex VAT
£372.08 inc VAT
The rack fan tray is a low cost solution that aids in heat removal from a Netshelter enclosure. The system easily installs into the top of the enclosure and expels heat from the roof of the rack. The fan trays are designed to promote bottom to top airflow within the enclosure.
  • Ships fully assembled
    NetShelter VX Enclosures ship fully assembled reducing the time required to install equipment
  • Facilitates overhead cable management
    Overhead cable troughs and partitions install toollessly on the roof of the enclosure eliminating the need for ceiling mounted or underfloor mounted cable trays. Cable troughs and partitions are designed to manage both power and data cables while maintaining separation
  • Fan guards
    A safety measure that provides protection from the fan opening by covering the inlet
APC Roof Fan Tray - rack fan tray
Rack fan tray
AC 208/230 V
57.4 cm x 89.3 cm x 6 cm
8.4 kg
NetShelter SX Enclosure with Sides
Rack fan tray
AC 208/230 V
57.4 cm
89.3 cm
6 cm
8.4 kg
VDE, UL 60950, CSA 22.2 No. 60950
Limited warranty: - 2 years
APC NetShelter SX Enclosure with Sides
Brand: APC
