APC Netshelter SX Roof Fan Tray 208-230 VAC 750mm
Quicklinx: 8B7QWS00 Mfr#: ACF504
Depth (mm): 89.3cm
Width (mm): 72.4cm
£454.40 ex VAT
£545.28 inc VAT
The APC Rack Fan Tray is a low cost solution that aids in heat removal from a Netshelter Enclosure. The system easily installs into the top of the enclosure and expels heat from the roof of the rack. The ACF504 fan tray promotes bottom to top airflow for a Netshelter SX enclosure in zero U of space. Cools by exhausting heat out of the roof of the rack.
This product is designed for Netshelter SX 750 mm.
  • Promotes Proper Airflow
    Helps to maintain proper rack temperatures within the enclosure by promoting top to bottom airflow movement
  • Fan guards
    A safety measure that provides protection from the fan opening by covering the inlet
APC Roof Fan Tray - rack fan tray
Rack fan tray
AC 208/230 V
72.4 cm x 89.3 cm x 6 cm
10.2 kg
NetShelter SX
Rack fan tray
AC 208/230 V
72.4 cm
89.3 cm
6 cm
10.2 kg
UL 60950, CSA 22.2 No. 60950
Limited warranty: - 2 years
APC NetShelter SX
Depth (mm): 89.3cm
Width (mm): 72.4cm
Brand: APC
