The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
Robust design
The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments. -
Seamless compatibility
Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
- APC NetShelter SX Enclosure with Roof and Sides - rack - 48U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 48U
- 60 cm x 120 cm x 226 cm
- 150 kg
- Wheels
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 48U
- 60 cm
- 120 cm
- 226 cm
- 150 kg
- Black
- Weight Limit
- 1364 kg
- Wheels
- EIA-310-D, IEC 60529 IP20, BAA
- TAA Compliant
- Limited warranty: - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £205.78 |
APC 1U Vertical Cable Organiser | In Stock | £125.84 |
APC 1U Horizontal Cable Organiser | In Stock | £55.58 |
APC Smart-UPS SC 450VA 1U | In Stock | £282.90 |
APC Netshelter heavy duty shelf | In Stock | £143.45 |
APC Rack PDU, Basic, Zero U, 10A,2 | In Stock | £279.25 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £209.01 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £304.99 |
APC Smart-UPS 5000VA | In Stock | £3,674.30 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £329.09 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £294.10 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,196.21 |
APC Cable Managers (Qty 10) | In Stock | £36.45 |
APC 2G Power distribution strip | In Stock | £655.79 |
APC Rack PDU 2G METERED ZEROU | In Stock | £702.35 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,324.93 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 | In Stock | £516.04 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,686.04 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,002.83 |
APC 19" Rack LCD Console | In Stock | £1,382.20 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.65 |
APC Switched Rack PDU 2G Zero U Power Distribution Unit | In Stock | £1,514.36 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £99.85 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,466.53 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,922.81 |
APC Smart-UPS SRT UPS 5000 Watt Lead Acid | In Stock | £4,086.20 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £973.42 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.21 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,800.92 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.30 |
APC Smart-UPS SRT 8000VA RM 230V | In Stock | £6,198.22 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,752.69 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £69.93 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,398.94 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,651.31 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £639.92 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,814.79 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,838.10 |
APC Metered Rack PDU | In Stock | £863.48 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,189.09 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £765.51 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,128.72 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £62.95 |
APC Smart-UPS SRT 10000VA RM 230V | In Stock | £7,507.55 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £683.92 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £604.80 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £720.88 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £901.64 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,274.18 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £164.46 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,309.42 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £83.56 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,544.66 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £466.62 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,120.20 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,942.30 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,272.53 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £527.92 |
