APC NetShelter SX 48U 600mm Wide x 1200mm Deep
Quicklinx: 53T9WS00 Mfr#: AR3307
Depth (mm): 120cm
Type: Floor standing
U Height: 48U
Width (mm): 60cm
£2,156.97 ex VAT
£2,588.36 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
  • Robust design
    The APC NetShelter SX Enclosure with Roof and Sides is crafted to provide a sturdy and reliable housing solution for your computing equipment. Its robust design ensures your PC components are well-protected against physical impacts and environmental factors, offering peace of mind for the security and longevity of your technology investments.
  • Seamless compatibility
    Designed with PC compatibility in mind, this rack seamlessly integrates with your existing computing setup. It eliminates the hassle of mismatched components, ensuring a smooth and efficient organization of your PC hardware within a secure enclosure.
APC NetShelter SX Enclosure with Roof and Sides - rack - 48U
Rack
Rack Size
19"
Height (Rack Units)
48U
60 cm x 120 cm x 226 cm
150 kg
Wheels
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
48U
60 cm
120 cm
226 cm
150 kg
Weight Limit
1364 kg
Wheels
EIA-310-D, IEC 60529 IP20, BAA
TAA Compliant
Limited warranty: - 5 years
53T9 APC Basic Rack-Mount PDU - power distribution strip In Stock £206.60
53T9 APC 1U Vertical Cable Organiser In Stock £125.43
53T9 APC 1U Horizontal Cable Organiser In Stock £56.26
53T9 APC Smart-UPS SC 450VA 1U In Stock £286.37
53T9 APC Netshelter heavy duty shelf In Stock £144.42
53T9 APC Rackmount Rail Kit In Stock £92.04
53T9 APC Smart-UPS 5000VA In Stock £3,747.89
53T9 APC Rack PDU Basic Zero U 32A 230V In Stock £330.64
53T9 APC Smart-UPS RT 20kVA RM 230V In Stock £12,532.22
53T9 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £297.98
53T9 APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,212.30
53T9 APC Cable Managers (Qty 10) In Stock £36.89
53T9 APC 2G Power distribution strip In Stock £654.12
53T9 APC Rack PDU 2G METERED ZEROU In Stock £710.98
53T9 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,358.63
53T9 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,716.21
53T9 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,015.17
53T9 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
53T9 APC Fixed Shelf - 50lbs/23kg, Black In Stock £82.14
53T9 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,498.11
53T9 APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,490.83
53T9 APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,960.39
53T9 APC 1U Blanking Panel Kit In Stock £35.27
53T9 APC Smart-UPS SRT UPS 5000 Watt Lead Acid In Stock £4,234.63
53T9 APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £983.97
53T9 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.94
53T9 APC Smart-UPS SRT 6000VA RM 230V In Stock £4,899.97
53T9 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.73
53T9 APC Smart-UPS SRT 8000VA RM 230V In Stock £6,334.13
53T9 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,743.67
53T9 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.10
53T9 APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,420.04
53T9 APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,668.22
53T9 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
53T9 APC Smart-UPS SRT 2200VA RM 230V In Stock £1,822.76
53T9 APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,842.92
53T9 APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,210.99
53T9 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £744.71
53T9 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,113.73
53T9 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.93
53T9 APC Smart-UPS SRT 10000VA RM 230V In Stock £7,694.98
53T9 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
53T9 APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £610.98
53T9 APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £725.85
53T9 APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £911.48
53T9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,285.92
53T9 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £166.36
53T9 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,325.53
53T9 APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,546.64
53T9 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.18
53T9 APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,233.09
53T9 APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,962.93
53T9 APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,294.47
53T9 APC Smart-UPS 750VA RM 230V SmartConnect In Stock £534.18
Resources
The following resources are available for the APC NetShelter SX 48U 600mm Wide x 1200mm Deep
Depth (mm): 120cm
U Height: 48U
Width (mm): 60cm
Brand: APC
Price Range Ex VAT: £1500+
