The APC NetShelter is a multi-functional rack enclosure influenced by customer feedback from around the world. These enclosures are designed to meet current IT market trends and applications ranging from high density computing and networking to broadcast and audio-video. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter rack enclosure provides a reliable rack-mounting environment for mission-critical equipment.
NetShelter SX networking enclosure expands APC's superior IT enclosure line with improved support for high density networking applications. Integrated high density cable managers and improved cable access roof provide support for large cable bundles.
Integrated high density cable management
Decrease installation time while supporting the cabling needs of large networking switches. -
Cable protection and pass-through
Smooth plastic fingers provide proper bend radius. -
Improved cable access
Maintain and organize large cable bundles for improved efficiency with open vertical mounting rails and large cable openings in roof. -
High density cable management
The vertical mounting rails are opened up for increased cable access and the roof design has large open areas for cable entry/exit from the enclosure. -
Optimized enclosure design for side-to-side airflow
Airflow management panels, left vertical mounting rail, and side airflow duct kit ensure proper side-to-side airflow to the networking switches from the cold aisle and provide isolation of hot air preventing it from re-entering the cold aisle. Additionally, the front left vertical mounting rail acts as an air block for exhaust air from networking switches.
- APC NetShelter SX Enclosure with Sides - rack - 42U - TAA Compliant
- Product Type
- Rack
- Black
- Height (Rack Units)
- 42U
- 75 cm x 120 cm x 199 cm
- 161 kg
- TAA Compliant
- 5-year warranty
- Product Type
- Rack
- 42U
- 75 cm
- 120 cm
- 199 cm
- 161 kg
- Black
- EIA-310-E, RoHS, UL 60950-1, REACH, BAA
- TAA Compliant
- Limited warranty: - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £206.60 |
APC 1U Vertical Cable Organiser | In Stock | £125.43 |
APC 1U Horizontal Cable Organiser | In Stock | £56.26 |
APC Smart-UPS SC 450VA 1U | In Stock | £286.37 |
APC Netshelter heavy duty shelf | In Stock | £144.42 |
APC Rackmount Rail Kit | In Stock | £92.04 |
APC Smart-UPS 5000VA | In Stock | £3,727.60 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £330.64 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,365.43 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £297.98 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,212.30 |
APC Cable Managers (Qty 10) | In Stock | £36.89 |
APC Rack PDU 2G METERED ZEROU | In Stock | £710.98 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,358.89 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,733.72 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £1,015.17 |
APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & | In Stock | £973.78 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £82.14 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £98.60 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,490.83 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,960.39 |
APC 1U Blanking Panel Kit | In Stock | £35.27 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £983.97 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.94 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.73 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,743.67 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.10 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,420.33 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,668.22 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £647.80 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,822.76 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,827.53 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,210.99 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £744.71 |
APC Switched Rack PDU AP7922B Power Distribution Unit | In Stock | £1,113.73 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £682.35 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £610.98 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £725.85 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £911.48 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,285.92 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £166.36 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,325.53 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £84.59 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,546.64 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £468.18 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,215.58 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,962.93 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,294.78 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £534.18 |
