APC NetShelter SX 42U 750mm Wide x 1200mm Deep Networking Enclos
Quicklinx: 86D5WS00 Mfr#: AR3340
Depth (mm): 120cm
Type: Floor standing
U Height: 42U
Width (mm): 75cm
£2,517.29 ex VAT
£3,020.74 inc VAT
The APC NetShelter is a multi-functional rack enclosure influenced by customer feedback from around the world. These enclosures are designed to meet current IT market trends and applications ranging from high density computing and networking to broadcast and audio-video. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter rack enclosure provides a reliable rack-mounting environment for mission-critical equipment.
NetShelter SX networking enclosure expands APC's superior IT enclosure line with improved support for high density networking applications. Integrated high density cable managers and improved cable access roof provide support for large cable bundles.
  • Integrated high density cable management
    Decrease installation time while supporting the cabling needs of large networking switches.
  • Cable protection and pass-through
    Smooth plastic fingers provide proper bend radius.
  • Improved cable access
    Maintain and organize large cable bundles for improved efficiency with open vertical mounting rails and large cable openings in roof.
  • High density cable management
    The vertical mounting rails are opened up for increased cable access and the roof design has large open areas for cable entry/exit from the enclosure.
  • Optimized enclosure design for side-to-side airflow
    Airflow management panels, left vertical mounting rail, and side airflow duct kit ensure proper side-to-side airflow to the networking switches from the cold aisle and provide isolation of hot air preventing it from re-entering the cold aisle. Additionally, the front left vertical mounting rail acts as an air block for exhaust air from networking switches.
APC NetShelter SX Enclosure with Sides - rack - 42U - TAA Compliant
Rack
Height (Rack Units)
42U
75 cm x 120 cm x 199 cm
161 kg
TAA Compliant
5-year warranty
Rack
Height (Rack Units)
42U
75 cm
120 cm
199 cm
161 kg
EIA-310-E, RoHS, UL 60950-1, REACH, BAA
TAA Compliant
Limited warranty: - 5 years
86D5 APC Basic Rack-Mount PDU - power distribution strip In Stock £206.60
86D5 APC 1U Vertical Cable Organiser In Stock £125.43
86D5 APC 1U Horizontal Cable Organiser In Stock £56.26
86D5 APC Smart-UPS SC 450VA 1U In Stock £286.37
86D5 APC Netshelter heavy duty shelf In Stock £144.42
86D5 APC Rackmount Rail Kit In Stock £92.04
86D5 APC Smart-UPS 5000VA In Stock £3,747.89
86D5 APC Rack PDU Basic Zero U 32A 230V In Stock £330.64
86D5 APC Smart-UPS RT 20kVA RM 230V In Stock £12,532.22
86D5 APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 In Stock £297.98
86D5 APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,212.30
86D5 APC Cable Managers (Qty 10) In Stock £36.89
86D5 APC 2G Power distribution strip In Stock £654.12
86D5 APC Rack PDU 2G METERED ZEROU In Stock £710.98
86D5 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,358.63
86D5 APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,716.21
86D5 APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,015.17
86D5 APC Rack PDU 2G Switched ZeroU 20A/208V 16A/230V (7) C13 & In Stock £973.78
86D5 APC Fixed Shelf - 50lbs/23kg, Black In Stock £82.14
86D5 APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,498.11
86D5 APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,490.83
86D5 APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,960.39
86D5 APC 1U Blanking Panel Kit In Stock £35.27
86D5 APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £983.97
86D5 APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.94
86D5 APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.73
86D5 APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,743.67
86D5 APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £70.10
86D5 APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,420.04
86D5 APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,668.22
86D5 APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £647.80
86D5 APC Smart-UPS SRT 2200VA RM 230V In Stock £1,822.76
86D5 APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,842.92
86D5 APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,210.99
86D5 APC Switched Rack PDU AC 208-230 V Ethernet In Stock £744.71
86D5 APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,113.73
86D5 APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £63.93
86D5 APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £682.35
86D5 APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £610.98
86D5 APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £725.85
86D5 APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £911.48
86D5 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,285.92
86D5 APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £166.36
86D5 APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,325.53
86D5 APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,546.64
86D5 APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £468.18
86D5 APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,233.09
86D5 APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,962.93
86D5 APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,294.47
86D5 APC Smart-UPS 750VA RM 230V SmartConnect In Stock £534.18
Depth (mm): 120cm
U Height: 42U
Width (mm): 75cm
Brand: APC
Price Range Ex VAT: £1500+
