The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
- APC NetShelter SX Enclosure with Sides - rack - 42U
- Product Type
- Rack
- Black
- Rack Size
- 19"
- Height (Rack Units)
- 42U
- 60 cm x 107 cm x 199 cm
- 125 kg
- Wheels, keyed alike, adjustable depth
- 5-year warranty
- Product Type
- Rack
- Rack Size
- 19"
- 42U
- 60 cm
- 107 cm
- 199 cm
- 125 kg
- Black
- Weight Limit
- 1364 kg
- Mounting Kit
- Included
- EIA-310-D, UL 60950, IEC 60529 IP20, RoHS, BAA
- TAA Compliant
- Limited warranty: parts and labour - 5 years
APC Basic Rack-Mount PDU - power distribution strip | In Stock | £202.03 |
APC 1U Vertical Cable Organiser | In Stock | £122.75 |
APC 1U Horizontal Cable Organiser | In Stock | £54.86 |
APC Smart-UPS SC 450VA 1U | In Stock | £283.64 |
APC Netshelter heavy duty shelf | In Stock | £142.89 |
APC - rack cable guide - 1U | In Stock | £51.09 |
APC Rackmount Rail Kit | In Stock | £92.13 |
APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT | In Stock | £206.47 |
APC Rack PDU Basic Zero U 16A 208/230V | In Stock | £299.80 |
APC Smart-UPS 5000VA | In Stock | £3,719.28 |
APC Rack PDU Basic Zero U 32A 230V | In Stock | £320.46 |
APC Smart-UPS RT 20kVA RM 230V | In Stock | £12,203.57 |
APC Equipment Support Rails for 600mm Wide Enclosure | In Stock | £73.19 |
APC Rack PDU Basic 1U 16A 208&230V (10)C13 & (2)C19 | In Stock | £287.81 |
APC Smart-UPS X 1500VA Rack/Tower LCD 230V | In Stock | £1,193.02 |
APC Cable Managers (Qty 10) | In Stock | £35.34 |
APC 2G Power distribution strip | In Stock | £645.98 |
APC Rack PDU 2G METERED ZEROU | In Stock | £689.69 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V | In Stock | £2,353.94 |
APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card | In Stock | £2,681.70 |
APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 | In Stock | £984.76 |
APC 19" Rack LCD Console | In Stock | £1,385.59 |
APC Fixed Shelf - 50lbs/23kg, Black | In Stock | £81.00 |
APC NetShelter Zero U Accessory Mounting Bracket | In Stock | £66.29 |
APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U | In Stock | £1,480.64 |
APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA | In Stock | £1,926.85 |
APC 1U Blanking Panel Kit | In Stock | £34.72 |
APC Smart-UPS SRT UPS 5000 Watt Lead Acid | In Stock | £4,213.46 |
APC Smart-UPS 1500VA LCD RM 1U 230V | In Stock | £975.09 |
APC M6 Hardware Kit Rack Screws, Nuts and Washers | In Stock | £56.96 |
APC Smart-UPS SRT 6000VA RM 230V | In Stock | £4,861.35 |
APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 | In Stock | £48.30 |
APC Smart-UPS SRT 8000VA RM 230V | In Stock | £6,205.09 |
APC Rack PDU 2G Metered ZeroU 22.0kW | In Stock | £1,694.93 |
APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided | In Stock | £70.94 |
APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V | In Stock | £2,403.60 |
APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net | In Stock | £1,654.55 |
APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V | In Stock | £636.90 |
APC Smart-UPS SRT 2200VA RM 230V | In Stock | £1,802.70 |
APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid | In Stock | £2,820.75 |
APC Metered Rack PDU | In Stock | £846.52 |
APC Smart-UPS 1500VA RM 230V w/Network Card | In Stock | £1,202.40 |
APC Switched Rack PDU AC 208-230 V Ethernet | In Stock | £736.14 |
APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U | In Stock | £264.70 |
APC Basic Rack PDU AP6015A Power Distribution Unit | In Stock | £60.44 |
APC Smart-UPS SRT 10000VA RM 230V | In Stock | £7,572.57 |
APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 | In Stock | £671.74 |
APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) | In Stock | £605.09 |
APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) | In Stock | £722.53 |
APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) | In Stock | £905.28 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU | In Stock | £1,258.20 |
APC Basic PDU 1/2 Height 100-240V/20A 14xC13 | In Stock | £162.29 |
APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 | In Stock | £1,287.30 |
APC Rack PDU Basic 0U/1U 100-240V/ | In Stock | £81.93 |
APC Smart UPS 2200VA LCD RM 2U 230 | In Stock | £1,535.30 |
APC Metered Rack 12A 1U C13x8 Power Distribution Unit | In Stock | £470.30 |
APC Smart-UPS SRT 3000VA RM Network Card | In Stock | £3,207.79 |
APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ | In Stock | £1,954.90 |
APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V | In Stock | £2,289.38 |
APC Smart-UPS 750VA RM 230V SmartConnect | In Stock | £531.44 |
