APC NetShelter SX 42U 600mm x 1070mm Deep Enclosure
Quicklinx: 4TPHWS00 Mfr#: AR3100
Depth (mm): 107cm
Type: Floor standing
U Height: 42U
Width (mm): 60cm
£1,387.87 ex VAT
£1,665.44 inc VAT
The APC NetShelter SX is the next generation rack enclosure solution influenced by 10 years of customer feedback and addresses current IT market trends for high-density server and networking applications. With a strong focus on cooling, power distribution, cable management and environmental monitoring, the NetShelter SX provides a reliable rack-mounting environment for mission-critical equipment.
APC NetShelter SX Enclosure with Sides - rack - 42U
Rack
Rack Size
19"
Height (Rack Units)
42U
60 cm x 107 cm x 199 cm
125 kg
Wheels, keyed alike, adjustable depth
5-year warranty
Rack
Rack Size
19"
Height (Rack Units)
42U
60 cm
107 cm
199 cm
125 kg
Weight Limit
1364 kg
Mounting Kit
Included
EIA-310-D, UL 60950, IEC 60529 IP20, RoHS, BAA
TAA Compliant
Limited warranty: parts and labour - 5 years
4TPH APC Basic Rack-Mount PDU - power distribution strip In Stock £205.78
4TPH APC 1U Vertical Cable Organiser In Stock £125.84
4TPH APC 1U Horizontal Cable Organiser In Stock £55.58
4TPH APC Smart-UPS SC 450VA 1U In Stock £282.90
4TPH APC Netshelter heavy duty shelf In Stock £143.45
4TPH APC Rack PDU, Basic, Zero U, 10A,2 In Stock £279.25
4TPH APC Smart-UPS RT 19inch Rail Kit for Smart-UPS RT In Stock £209.01
4TPH APC Rack PDU Basic Zero U 16A 208/230V In Stock £304.99
4TPH APC Smart-UPS 5000VA In Stock £3,674.30
4TPH APC Rack PDU Basic Zero U 32A 230V In Stock £329.09
4TPH APC Smart-UPS X 1500VA Rack/Tower LCD 230V In Stock £1,196.21
4TPH APC Cable Managers (Qty 10) In Stock £36.45
4TPH APC 2G Power distribution strip In Stock £655.79
4TPH APC Rack PDU 2G METERED ZEROU In Stock £702.35
4TPH APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V In Stock £2,324.93
4TPH APC 1U 19" Black Modular Toolless Blanking Panel - Qty 200 In Stock £516.04
4TPH APC Smart-UPS X 3000VA Rack/Tower LCD 200-240V w/ Network Card In Stock £2,686.04
4TPH APC Rack PDU 2G, Metered, ZeroU, 11kW, 230V, (36) C13 & (6) C19 In Stock £1,002.83
4TPH APC 19" Rack LCD Console In Stock £1,382.20
4TPH APC Vertical Cable Organizer, NetShelter SX, 42U In Stock £96.64
4TPH APC Fixed Shelf - 50lbs/23kg, Black In Stock £81.65
4TPH APC Switched Rack PDU 2G Zero U Power Distribution Unit In Stock £1,514.36
4TPH APC NetShelter Zero U Accessory Mounting Bracket In Stock £99.85
4TPH APC Smart-UPS X 2200VA Rack/Tower LCD 200-240V - 4U In Stock £1,466.53
4TPH APC Smart-UPS X 3000 Rack/Tower LCD 2700 Watt 3000 VA In Stock £1,922.81
4TPH APC Smart-UPS SRT UPS 5000 Watt Lead Acid In Stock £4,086.20
4TPH APC Smart-UPS 1500VA LCD RM 1U 230V In Stock £973.42
4TPH APC M6 Hardware Kit Rack Screws, Nuts and Washers In Stock £56.21
4TPH APC Smart-UPS SRT 6000VA RM 230V In Stock £4,800.92
4TPH APC 1U 19" Black Modular Toolless Blanking Panel - Qty 10 In Stock £48.30
4TPH APC Smart-UPS SRT 8000VA RM 230V In Stock £6,198.22
4TPH APC Rack PDU 2G Metered ZeroU 22.0kW In Stock £1,752.69
4TPH APC Horizontal Cable Manager, 1U x 4" Deep, Single-Sided In Stock £69.93
4TPH APC SMX3000HVNC Smart-UPS X1500VA Rack/Tower LCD230V In Stock £2,398.94
4TPH APC SMX1500RMI2UNC Smart-UPS 1500VA Rack/Tower LCD 230V with Net In Stock £1,651.31
4TPH APC Rack PDU 2G Metered ZeroU 20A/208V 16A/230V In Stock £639.92
4TPH APC Smart-UPS SRT 2200VA RM 230V In Stock £1,814.79
4TPH APC Smart-UPS SRT 3000VA RM 2700 Watt 3000 VA - Lead Acid In Stock £2,838.10
4TPH APC Metered Rack PDU In Stock £863.48
4TPH APC Smart-UPS 1500VA RM 230V w/Network Card In Stock £1,189.09
4TPH APC Switched Rack PDU AC 208-230 V Ethernet In Stock £765.51
4TPH APC Vertical Cable Manager for NetShelter SX 750mm Wide 42U In Stock £268.40
4TPH APC Switched Rack PDU AP7922B Power Distribution Unit In Stock £1,128.72
4TPH APC Basic Rack PDU AP6015A Power Distribution Unit In Stock £62.95
4TPH APC Smart-UPS SRT 10000VA RM 230V In Stock £7,507.55
4TPH APC Switched Rack PDU AP7920B Power Distribution Strip AC 200/20 In Stock £683.92
4TPH APC Smart-UPS C 1000VA 2U LCD - UPS (rack-mountable) In Stock £604.80
4TPH APC Smart-UPS 1000VA LCD RM - UPS (rack-mountable) In Stock £720.88
4TPH APC Smart-UPS 1500VA LCD RM - UPS (rack-mountable) In Stock £901.64
4TPH APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU In Stock £1,274.18
4TPH APC Basic PDU 1/2 Height 100-240V/20A 14xC13 In Stock £164.46
4TPH APC Rack PDU 2G, Metered by Outlet with Switching, ZeroU, 16A, 2 In Stock £1,309.42
4TPH APC Rack PDU Basic 0U/1U 100-240V/ In Stock £83.56
4TPH APC Smart UPS 2200VA LCD RM 2U 230 In Stock £1,544.66
4TPH APC Metered Rack 12A 1U C13x8 Power Distribution Unit In Stock £466.62
4TPH APC Smart-UPS SRT 3000VA RM Network Card In Stock £3,120.20
4TPH APC Smart-UPS SMT3000RMI2UC - UPS (rack-mountable) - AC 220/ In Stock £1,942.30
4TPH APC Smart-UPS 3000VA LCD RM - UPS (Rack-Mountable) AC 230 V In Stock £2,272.53
4TPH APC Smart-UPS 750VA RM 230V SmartConnect In Stock £527.92
Resources
The following resources are available for the APC NetShelter SX 42U 600mm x 1070mm Deep Enclosure
Depth (mm): 107cm
U Height: 42U
Width (mm): 60cm
Brand: APC
Price Range Ex VAT: £1000 - £1500
